Water neck leak - Team Camaro Tech
post #1 of 6 (permalink) Old Dec 13th, 02, 08:59 AM Thread Starter
I have a O-ring type water neck that has a slow leak problem. I have already replaced it once and after I shut the car down it starts to leak, anyone have a solution to this problem without using a ton of silicone. Thanks, G
GIACOMO is offline
post #2 of 6 (permalink) Old Dec 13th, 02, 09:53 AM
The only sure cure method I have found is a thermostat housing gasket from GM. It has a silicone "O" ring built in to the gasket. Just a couple of bucks. Don't know if you can use it with your housing?
GMJim is offline
post #3 of 6 (permalink) Old Dec 13th, 02, 11:59 AM
I always make sure that the two surfaces are absolutely flat, free of burrs, then butter hylomar gasket dressing on the intake and cinch the two together. Never had a leak in 20 years. Your o ring gasket must contact both flat surfaces.You can always go to the hardware store in look of a slightly fatter o ring as well. Done that too.
STEVE "Jack'Stands" JACK
Techical forum/links at Jack'Stands TechForums and Links
HOTRODSRJ is offline
post #4 of 6 (permalink) Old Dec 13th, 02, 04:59 PM
get rid of the o-ring t-stat housing, and get a stock one off a car in the boneyard. it wil lbe cheap, and probably never leak. if you get one off a late model truck with efi- 87 or newer- it won't have the ugly thermostatic switches mounted on it, and be bolted on with 2 short bolts. i have header bolts holding mine on. wire brush it or polish it, and it will look pretty nice.
355sb, vortec heads, HOT cam,T-10 tranny, 3.70 gears 16X8" IROC wheels. 12" Corvette brakes on the way.
see pics here http://community.webshots.com/user/novaderrik
novaderrik is offline
post #5 of 6 (permalink) Old Dec 14th, 02, 02:17 AM
Chris
ckaram's Avatar
Novaderrik is dead-on....dump the O-ring housing.
I jerked around with this issue last summer. Put 2 of those things on and still leaked. Get one without the O-ring and you will be home free!
68 Camaro ragtop, original 327, angle plug Camel humps, 202's, Performer, Holley 650 double pumper, Doug Thorley headers, 3-speed Saginaw, 3.08 posi, subframe connectors, Addco sway bar
http://hobbystage.net/camaro/cjkaram/
ckaram is offline
post #6 of 6 (permalink) Old Dec 14th, 02, 12:15 PM
JohnZ's Avatar
Before you install it, work it back and forth on a piece of emery paper on a piece of glass (or flat, smooth bench top) and make sure the mating surface is flat. Fel-Pro makes a molded plastic gasket with silicone ribs molded into it that seals dry every time (without goop) and is re-usable many times - I've used them for years.
JohnZ
CRG
'69 Z28 Fathom Green
JohnZ is offline
