Clutch Fork Spring & Header - Team Camaro Tech
post #1 of 4 (permalink) Old Mar 8th, 01, 10:40 PM Thread Starter
My headers get in the way of my clutch fork return spring. I was thinking of getting a bracket welded onto my header for the spring. Is this a good idea? Anybody have the same problem? Is there an easier way?
Max
67 with muncie.
Maxwell is offline
post #2 of 4 (permalink) Old Mar 9th, 01, 02:56 AM
Rick
I used a 3 inch piece of flat stock, drilled a hole on either end and bolted it to the motor mount, leaving a small hole on the other end for the spring. Another member here was even cleverer. He used a hose clamp around a header tube to provide a place for the spring to attach.
RickD is offline
post #3 of 4 (permalink) Old Mar 9th, 01, 05:32 AM
Carl
The hose clamp works great! Just align the screw head so that the spring can clip over it.
Click here to see see my car and hear 5-speeds. http://www.geocities.com/casanoc
CarlC is offline
post #4 of 4 (permalink) Old Mar 12th, 01, 10:47 AM
I put a brcket on the frame, make sure it is heavy steel though.
David R is offline
