Throwing Alternator Belt - Team Camaro Tech
post #1 of 5 (permalink) Old Jul 15th, 02, 11:47 AM Thread Starter
I have put new pulleys on. Made sure the pulleys are in alignment. Even sanding the inside of the pulleys with sandpaper. I got a smaller belt to sit down deeper in the grooves. Still no luck. Stays on when cruising, but when a race an hit 7,000 rpm the belt must float and come off. Any help would be great.
turbo eric is offline
post #2 of 5 (permalink) Old Jul 15th, 02, 11:52 AM
had the same problem even went to new brackets to keep the alt from moving, still no luck. ended up with under drive pulleys no more problems. also some belts are softer an stretch more than other brands, good luck
storman is offline
post #3 of 5 (permalink) Old Jul 15th, 02, 04:29 PM
i had the same problem, get the pulleys off of 85-86 chev truck v-8, they have a serpentine drive for the water pump and alternator and v-belt for the power steering, but you will have to move the alt. to the passenger side. cost me 25 bucks for the pulleys and i have never had a problem since, and it looks good to boot. David
67 RS marina blue
SUPER T10 4 SPD
377, demon carb
91 formula 350 firebird (wifes car)
01 siverado 2500HD
67FREAK is offline
post #4 of 5 (permalink) Old Jul 15th, 02, 06:22 PM
Nick
Hi! I had the same problem a week a go with my a/c belt.I got every belt out there from a good/year to gates belts,and finaly dayco "TOP COG" BELT. It stays on all the way to 7500rpm no more problems.Good luck.Nick
MRCOOL_RSSS350 is offline
post #5 of 5 (permalink) Old Jul 19th, 02, 10:51 AM
JohnZ's Avatar
If you have the correct deep-groove pulleys and they're properly aligned and you use Dayco "Top Cog" belts, you won't throw any more belts. Almost any belt will work up to 5000 rpm, but above that, you need GOOD belts; I've NEVER thrown a "Top Cog" belt.
JohnZ
CRG
'69 Z28 Fathom Green
JohnZ is offline
