original 302 do you need to put lead additive - Team Camaro Tech
post #1 of 9 (permalink) Old Oct 10th, 02, 03:46 PM Thread Starter
is it true that you need to put lead aditive in or you will burn up your valves and seats? i run 104 octaine boost but no lead. is this the right thing to do?
68 rs z28 is offline
post #2 of 9 (permalink) Old Oct 11th, 02, 12:32 AM
It certainly wouldn't hurt.
Save your pennies, nickels, & dimes. Some day, you can pull the heads and have hardened exhaust seats installed, or buy some new alum heads. Put the originals in a garbage bag for safekeeping. Spray with lots of WD-40.
Everett "OBJECTS IN THE MIRROR DISAPPEAR UPON RAPID ACCELERATION"
Everett#2390 is online now
post #3 of 9 (permalink) Old Oct 11th, 02, 05:23 AM
DjD
DjD's Avatar
I don't have first hand experience on this but, it's been posted here before. If the engine is origional and has never been taken apart for head work the seats and seals should be well protected by years of leaded gas deposits.
Use the search engine in the old tech forums and I think you'll find more information on this...
...Dennis
"The '69, the '96 our local club"
and the "daily driver"
DjD is offline
post #4 of 9 (permalink) Old Oct 11th, 02, 05:31 AM
I remember I used something called CDR or CDJ additive that I got at walmart. If you just did a head job without putting in hardened seats, you really need to use something until it gets some built up on the seats. After that, a little goes a long way. Better safe than sorry
69 convertible
LT1 4L60E
red69camaro is offline
post #5 of 9 (permalink) Old Oct 11th, 02, 10:10 AM
Paul
PDQUICK's Avatar
You'll definitely hammer the valve seats if you didn't put in hardened seats when you rebuilt the engine. You'll get about 10-15K miles out of the heads before it gets ugly. Less mileage if you have big springs!!
PDQUICK is offline
post #6 of 9 (permalink) Old Oct 11th, 02, 12:26 PM
If you run a blend of 5 gallons of leaded race fuel with premium unleaded for 2 tankfulls you will be fine. That is how I did mine. The most important thing to do is lash the valves right at .026/.026 if you are running stock rockers. I posted on this recently so take a look. That is the best way to save your heads.
-Mark.
stingr69 is offline
post #7 of 9 (permalink) Old Oct 12th, 02, 12:57 PM
Paul
PDQUICK's Avatar
Just found some Bardhal stuff at the auto parts store this morning. It's called "Instead O' Lead". It cost $1.50 and says it will treat 20 gallons.
Anybody know if I should trust my 35 yr old fuelies to this stuff???
PDQUICK is offline
post #8 of 9 (permalink) Old Oct 14th, 02, 07:24 AM
If you want to protect your heads from valve seat regression, its a good idea to use one of the lead substitutes. All of the substitutes are based on either phosphorus, potassium, sodium or manganese compounds. If I remember correctly, sodium and phosphorus work a little better. I believe that Instead 'O Lead is sodium based.
Also, most of the lead substitutes have other additives like cleaners and/or octane boosters.
bowtie-70 is offline
post #9 of 9 (permalink) Old Oct 19th, 02, 04:29 AM
Paul
PDQUICK's Avatar
Thanks Bowtie,
It sounds like this stuff is good, cheap insurance!!
PDQUICK is offline
