rough idle/backfire - Team Camaro Tech
post #1 of 7 (permalink) Old Apr 25th, 01, 10:41 AM Thread Starter
I need help! My 93 TA is idling rough(like it has a big cam)and backfires when i let of the gas to shift. there are no codes, I can't seem to find a vaccum leak( but I may have overlooked it). I have replaced the plugs,wires,coil,distributor,and fuel injectors. Any ideas?
Matty 93 TA is offline
post #2 of 7 (permalink) Old Apr 25th, 01, 11:59 AM
im not an expert but have you checked your timing?
insanechevy is offline
post #3 of 7 (permalink) Old Apr 25th, 01, 12:24 PM Thread Starter
If was checked last summer and it was right on.
post #4 of 7 (permalink) Old Apr 26th, 01, 02:40 AM
like i said im not an expert by any means compared to these guys but check it and make sure is still right on. im still learning so im sorry i cant help you more
post #5 of 7 (permalink) Old Apr 26th, 01, 09:36 PM
Is it a tpi motor? A coworker had the same trouble with his tpi 350 85 vette...it had a vac leak from a bad runner gasket on his tpi...and it was a real PITA to change the the runner gaskets.
375hp 78 Chevy truck
77 Chevy Nova
95 Chevy Lumina 3.4L
and building a 78 Nova
travis is offline
post #6 of 7 (permalink) Old Apr 29th, 01, 06:34 PM
I know this sounds like a repeat.but your new to the site. Looks like you,ve spent enough money guessing.Take it to a good dealer or garage for a complete fuel & EEC (electronic engine controls) Diag.
69 Camaro SS 350 4 speed
55 Belair Sedan Pro Street 355 auto 9''
gene stills is offline
post #7 of 7 (permalink) Old Apr 30th, 01, 11:12 AM
Chuck
this may be in the wrong direction, but check for an exhaust leak. the same symptoms happen when i unplug my headers because of the pressure change in the exhaust when i let off of the gas and shift. There is not enough pressure in the system some pressure is needed if you run at low rpms, and are not just shooting down a quarter mile. that is why most street cars run better with the mufflers on the car. you probably have a bad exhaust doughnut or the pipe has come loose at the manifold. good luck.
chuck
67 rs/ss 360 blue w/black vinyl top
cfry is offline
