Heater? - Team Camaro Tech
post #1 of 3 (permalink) Old Nov 14th, 99, 02:57 PM Thread Starter
I have an 89 IROC and the heater is not working. The car runs at normal temperature. I have replaced the heater valve, flushed the system, and replaced the thermostat. There is still no heat. I have checked my damper doors and they all seem to be in proper working order. It seems to blow warm at times, but surely not hot. If you know what my problem is, please E-mail me at [email protected]. Thank you for your time and help.
GrimReape2 is offline
post #2 of 3 (permalink) Old Nov 18th, 99, 11:41 AM
Almost sounds like a plugged up heater core. Can you verify the flow to the core itself ?, If the rest of the coolong system is operating properly this may be a possibility. I'm not sure how the newer cars like yours are, but I know the older ones like mine were susceptable to clogging and corrosion that reduced effectiveness. I'm in the process of replacing the core in my 69.
Shawn is offline
post #3 of 3 (permalink) Old Nov 22nd, 99, 07:51 PM
David Pozzi
davidpozzi's Avatar
Most GM heaters have a door that opens and diverts air from the heater core to the inside.
Frequently a pen or other object gets dropped into the defroster outlet and jams the door. Some doors are controlled by a vaccum actuator and a hose gets disconnected or there is a leak or pinched hose.
davidpozzi is offline
