96 Camaro - Team Camaro Tech
post #1 of 5 (permalink) Old Feb 24th, 00, 03:04 AM Thread Starter
I just recently purchased a 96 Camaro and occasionally when I brake the low trac light will come on a few times only during braking then eventualy it will disengage the abs system...Any suggestions? I'd like to know alittle about it before I go to the dealer for the ream job...ha ha...Thanks
whtrose3 is offline
post #2 of 5 (permalink) Old Feb 24th, 00, 09:54 AM
i think u need to takr it to the dealer b/c it sounds like it has a major short some were wich soon u might not have brakes
hurljack is offline
post #3 of 5 (permalink) Old Apr 21st, 00, 10:26 AM
I have a 94 camaro and it did that when I first got mine two years ago. The low trac light came on and eventually the ABS light came on also. All I did was replace the break pads. Then it stopped. It started back a few weeks ago and sure enough, the break pads needed replaced. Might be something to look at.
Jennifer is offline
post #4 of 5 (permalink) Old Apr 24th, 00, 09:49 AM
this is a duplicate post , stick to the original one.
Chris's 67 RS can be seen at http://www.geocities.com/macphreak4evr/index.html
JOIN THE CAMARO NET WEBRING! www.geocities.com/macphreak4evr/webring/webringjoin.htm !!!
Chris Edwards is offline
post #5 of 5 (permalink) Old Apr 25th, 00, 02:02 AM Thread Starter
Posted from the original: It seems to only do it when I keep the 35 PSI recommended tire pressure...other than that I don't have any other problems with the system.
whtrose3 is offline
