GM 1 wire alternator not charging battery - Team Camaro Tech
post #1 of 13 (permalink) Old Jan 31st, 13, 10:41 AM Thread Starter
Matt
Hey, I have a 68 Camaro with a 400 small block. I just replaced the alternator which is a GM 1 wire alternator. A while back I had a headlight switch short out and fry my electrical system so I had the entire wiring harness replaced. Car was running fine until a few days ago. My starter went out so I replaced it and once again running fine. Today I find that my battery is dead and after jumping it the alternator light was on and not charging battery. Had the old one tested and it was bad, but the new one tested good at 3 different shops and is still not putting out any voltage. Is it possible that the solenoid on the starter is bad? The battery will hold a full charge and car starts and runs fine but there's no voltage coming off the alternator. I'm at a loss here.
Reaper138 is offline
post #2 of 13 (permalink) Old Jan 31st, 13, 11:28 AM
Vintage 68's Avatar
Wink Re: GM 1 wire alternator not charging battery
You may want to spend a little time reading through - http://www.madelectrical.com/electri...hreewire.shtml
1968 Convertible
Some trucks
Vintage 68 is offline
post #3 of 13 (permalink) Old Jan 31st, 13, 01:03 PM Thread Starter
Matt
Ignore the arrows in the picture, it was the best pic i could find.
This is what the old one looked like and it's also what the new one looked like. I took the old one to autozone and because it's not the stock engine in the car they were running around with their heads off because they couldn't use the computer to solve this problem. The guy ended up bringing the new one out and the box said GM 1 wire on it. The part number was DL7140M. I don't have the old one anymore but at this point I'm wondering if maybe I need a 3 wire with internal voltage regulator like in this picture? how do I tell the difference, they look identical. If it helps, i do have the GEN light in the dash and from what I read since that's lighting up I would think that I need a 3 wire but I have no idea.
post #4 of 13 (permalink) Old Jan 31st, 13, 02:33 PM
Allen
I agree with Vintage '68 and bone up on the one wire alternators.
When I had my '71, I went to the one wire alternator and did not like it. The one wire setup would only charge the battery, under load. It was particularly noticeable at night when the lights were on. It was very annoying to have the lights dim, when your're stopped sitting at a light. As soon as the RPM's picked up, the lights would get brighter.
If you can, go back to the three wire setup.
Just my 02 cents.
A
Kunihiro is offline
post #5 of 13 (permalink) Old Jan 31st, 13, 03:32 PM Thread Starter
Matt
Massive Face Palm. Alternator wire was bolted to the wrong side of the starter solenoid. Turns out the alternator is also a 1 or 3 wire hook up.
post #6 of 13 (permalink) Old Jan 31st, 13, 04:13 PM
kevin
Just my 02 cents.
A
not a problem with my one wire altenator, but i did have it built to 130 amps.
you can always go to a smaller pully on the altenator. that will speed it up and still maintain your rpm setting at idle
flat tire is offline
post #7 of 13 (permalink) Old Jan 31st, 13, 04:28 PM
Vintage 68's Avatar
Originally Posted by flat tire View Post
... can always go to a smaller pully on the altenator. that will speed it up and still maintain your rpm setting at idle
That would be a 'Larger' diameter Pulley - "to speed it up"
You do realize that an 'alternator' usually operates at @3 times faster than the crank speed of the engine - right ???
GM/Delco alternators are spec.d at;
@10k rpm for Continuous Duty shaft speed
@12K rpm for transient Intermittent shaft speed
@18K rpm as the Maximum shaft speed
So 'speeding it up' to much will have it throwing windings off the armature in a very short time.
Seen it happen and it's NOT a pretty sight
Designing and installing a fully functional charging system that operates under ALL conditions isn't Rocket-Surgery.
Lots of good posts/threads on this site with great info on how to do it ...
1968 Convertible
Some trucks
post #8 of 13 (permalink) Old Jan 31st, 13, 08:45 PM
mike
He said a larger pulley on the alternator. That would indeed speed it up. Think of it this way if he had a pulley the size of a bike tire it would barely spin fast at all, if he had one the size of a pea it would spin insanely fast. I have read tons of posts 3 wire vs 1 wire and can get a million opinions on what is best. I just think it is what is available and what you like. However it is important to get enough amperage to suit your needs. The o.p. I think if the stores say the alternator is good and the gen light is on he made a mistake with the wiring he needs to figure out.
bigblockragtop is offline
post #9 of 13 (permalink) Old Jan 31st, 13, 10:47 PM
Did you replace a 1 wire with another 1 wire? Hard to tell from your post. A 1 wire won't allow the factory gen light to work, hence the confusion.
BPOS is offline
post #10 of 13 (permalink) Old Feb 1st, 13, 12:37 PM Thread Starter
Matt
It's a GM alternator that accepts both 1 and 3 wire hookups. After a lot of research, i'm running a 3 wire and have been the whole time. Problem was that I had the alternator wired to a ground instead of the postive terminal on the battery. Just had to unbolt it and swap it to the opposite post on the starter solenoid and now it's working perfectly. Next time I'm taking pictures and notes when I take something apart for the first time.
post #11 of 13 (permalink) Old Feb 2nd, 13, 11:03 AM
mike
You said just had to swap it, did you mean you found out before you tried to connect the battery or after. Not sure what would happen if you did hook up the battery while the wires were backwards. Fry something maybe?
post #12 of 13 (permalink) Old Feb 3rd, 13, 01:34 PM Thread Starter
Matt
No I had the battery hooked up before I figured it out. Alternator was just grounding out so no electrical damage. Got lucky this time.
post #13 of 13 (permalink) Old Feb 9th, 13, 09:13 AM
madmax87's Avatar
I know he solved his issue but I don't think the pulley question is answered correctly. They stated reducing the size of the alt pulley would speed it up. This is correct. Increasing the size of the crank pulley would also speed it up. If you had a 4" crank and 4" alt running at 700rpms, they would be the same. If you had a 4" crank and 2" alt, the alt would be spinning at 1400. So to get a 3 to 1 ratio with a 4" crank your alt would have to be 1.33"
http://www.culvermotor.com/Engineeri...alculator.html
madmax87 is offline
