timing - Team Camaro Tech
post #1 of 5 (permalink) Old Dec 25th, 99, 12:28 AM Thread Starter
i am having trouble finding the correct timming on my 68 camaro, it has the origenal 327/275hp cid engine, and powerglide tranny, i was also told that i could hook up a vaccum gage and set the timing to the highest vaccum pressure. but that sets it to about 14 atdc...none of the stickers are on the car, so im prety lost as to what to set the timing to, and help is appreciated.
Cannibal is offline
post #2 of 5 (permalink) Old Dec 25th, 99, 03:53 AM
Drake
My Chiltons manual says 4degrees BTDC for your engine.If your engine has a few miles you might want to run it a few degrees advanced from there to compensate for timing chain stretch anyway.I usually tweak mine in by the way it runs,and use the manual just as a starting point.If you have had your disributor re-curved for example,it might run better at a setting different then what the manual says.
67drake is offline
post #3 of 5 (permalink) Old Dec 27th, 99, 10:54 AM
Set it at 10 btdc, that is the most popular setting. Factory recommendations are way off most of the time performance wise
jokerdwarf is offline
post #4 of 5 (permalink) Old Dec 27th, 99, 06:08 PM
Advance the timing as far as you can go, I set mine untill it will not crank over smoothly when it is hot, This is about the same spot where i don't have any detonation.
Rob.Canada is offline
post #5 of 5 (permalink) Old Dec 30th, 99, 09:09 AM
I have great results between 10 - 12 degrees
advance (set without vacuum advance hooked up).
camaroguy is offline
