TV Cable Adjusting - Team Camaro Tech
post #1 of 4 (permalink) Old Mar 19th, 01, 04:15 AM
rogleete
Guest
Posts: n/a
how do you adjust the TV Cable on a 700r4 to make it shift at higher rpm
post #2 of 4 (permalink) Old Mar 19th, 01, 10:04 AM
the tv cable is adjusted by connecting to the linkage on the carb/TBI/TPI and just pulling the throttle full open and releasing,assuming that it is still connected to the computer on the housing with a four pin connector.
danhon is offline
post #3 of 4 (permalink) Old Mar 19th, 01, 10:08 AM
to make it shift at a higher rpm you need to modify the valve body with a shift kit available from the aftermarket, like B&M.
danhon is offline
post #4 of 4 (permalink) Old Mar 19th, 01, 11:04 AM
DjD
DjD's Avatar
I respectfully disagree with danhon on both his recomondations. You need your TV to carb/TBI/TPI set up properly. The TV controls both when and how hard your 700 will shift. I'm not a tranny guy but I have a 700 in my '69 and don't want anyone to lunch a tranny based on advice given here. Angles as well as pull make things work!!
Contact www.700r4.com they will work with you to make sure you do it correctly.
...Dennis
'69 RS Convertible w/SS trim
'96 Z28SS #1679 of 2410
"The Club"
DjD is offline
