EFI Fuel filter - Team Camaro Tech
post #1 of 4 (permalink) Old Nov 10th, 01, 08:12 AM Thread Starter
Has anyone changed a in-line fuel filter in on an EFI type set-up? From reading the manufactures manual, it states that these filters are under constant pressure, even when the ignition is off. Is the pressure a true concern or is this something that can be done without special tools? Thanks in advance-Dino
Dino is offline
post #2 of 4 (permalink) Old Nov 10th, 01, 10:19 AM
They have to post that warning to try to keep people from getting hurt.Yes they are under pressure that can squirt fuel in your eyes but if you wrap a rag around fitting and loosen it til it discharges you'll be fine.you can also unplug fuel pump then crank engine for a few seconds to get the pressure out of line.If you have a fuel pressure gauge with a release button you can do that too.
sschevyfan is offline
post #3 of 4 (permalink) Old Nov 10th, 01, 03:37 PM
YEAH SSCHEVYFAN IS RIGHT HE`S HIGH TECH
LOOK -FOR THE BACK YARD JOE JUST FIND THE
SCHRADER VALVE ON THE FUEL LINE
AT THE INTAKE ,INSERT A THIN EDGE TOOL AND PUSH UNTIL THE PRESSURE DROPS ,IT WON`T SQUIRT HIGH OR
BAD SO WEAR SAFETY GLASSES ANYWAY,
THEN
CRAWL UNDER THE CAR AND USE A BUCKET SO THAT WHEN YOU
REMOVE THE FILTER THE FUEL
UNDER LOW PRESSURE WILL CATCH INTO THE BUCKET.DO YOUR RE +RE
IF YOU DO THE JOB THE WAY HIGH TECH DOES IT
THEN YOUR A PRO.
IS EASY GO FOR IT.................
rennycal is offline
post #4 of 4 (permalink) Old Nov 13th, 01, 03:08 PM
Joe
Ok i dont know about you other guys but I think sschevyfan and rennycal need to hug each other and stop nit picking each other. Cannt we all just get along.
70 camaro 307 (350soon) /350th
Joekool1234567 is offline
