No Headlights...HELP ! I can't see - Team Camaro Tech
post #1 of 6 (permalink) Old Aug 9th, 02, 12:06 PM Thread Starter
I've got side marker lights,parking lights,tail lights. No headlights. I replaced the headlight switch in the dash, didn't help. Tried new headlights, didn't help. Could someone please shead some light on my problem. Thank you very much.
porcam is offline
post #2 of 6 (permalink) Old Aug 9th, 02, 12:32 PM
What year? On my 67 I had a bad floor dimmer switch that caused the same problem. Pete
67 red camaro convertible, 78 silver anniversary vette, 1985 Z28 camaro, 1970 chevelle currently undergoing deer hit repair.
no1dc is offline
post #3 of 6 (permalink) Old Aug 9th, 02, 01:10 PM Thread Starter
1969 350 SS. Thanks, I'll check out the dimmer switch.
porcam is offline
post #4 of 6 (permalink) Old Aug 9th, 02, 01:42 PM
Mike, 69's rule
zuma's Avatar
Make sure your headlights are grounded, the ground should be on the radiator support next to the voltage regulator, good luck...MM
zuma is offline
post #5 of 6 (permalink) Old Aug 9th, 02, 01:57 PM
Those little bolts and wires around the voltage regular corrode. Thats probably close. I thought that too. But did you check your switch before you put it in?
http://www.geocities.com/macgse/68Ca...?1028936173510
Baby68RS is offline
post #6 of 6 (permalink) Old Aug 9th, 02, 02:28 PM Thread Starter
Pete,
I took the dimmer connection apart, cleaned the terminals and snapped the connection back together...I can see again!! I don't think that connection has been apart since 1969. Thank you for your help. Thank you all for your suggestions.
Delmar
porcam is offline
