Car Problems - Team Camaro Tech
post #1 of 4 (permalink) Old Jan 18th, 01, 04:17 AM Thread Starter
Unhappy
I need help diagnosing a car problem. I have a 1996 V6 camaro. When I shift into 2,3,and 4 gear my car drives fine. However, when I exelorate, my car tries to cut out and gives me hesitation. Is this a fuel filter, fuel pump, or fuel injection problem.
danieldrice is offline
post #2 of 4 (permalink) Old Jan 18th, 01, 05:27 AM
I would start with the easy stuff. Replace the fuel filter and stick in a can of Chevron Techron with the next fillup. If it still does it you may have a bad plug wire. Plug wires will not always misfire during normal operation but will under acceleration.
Good Luck,
onemorecamaro is offline
post #3 of 4 (permalink) Old Jan 18th, 01, 05:34 PM
Thomas
Check your fuel pressure, your fuel pump might be going bad.
70 1/2 RS Camaro
Slomaro is offline
post #4 of 4 (permalink) Old Jan 19th, 01, 07:37 PM
I had an Astro van and an '89 RS do the same thing, both times it was a bad coil. Wes
MY396 is offline
