misfire - Team Camaro Tech
post #1 of 3 (permalink) Old Nov 5th, 01, 06:22 PM Thread Starter
question on a 1994 Camaro Z28 (5.7L V8):
I recently changed my spark plugs and wires but the engine seems to be running even rougher than it was earlier. Anyone have any ideas why?
Z28Heathen is offline
post #2 of 3 (permalink) Old Nov 5th, 01, 06:35 PM
Joe
Make sure you plugged the wires all the way on the spark pluggs. They are hard to get to and that makes it easy for them not to click all the way on when thet are installed. Also make sure the wires are not running to close to the exhaust manifolds causing them to melt and arc.
70 camaro 307 (350soon) /350th
Joekool1234567 is offline
post #3 of 3 (permalink) Old Nov 5th, 01, 08:16 PM
Did you 'perhaps' crack a plug when you put it in?It does happen.If it runs worse now than it did before I would think it was something you did and I don't mean that snotty either.Go back over and check all the plugs out after you do like joekool1234567 said.
sschevyfan is offline
