cruise control - Team Camaro Tech
post #1 of 4 (permalink) Old Feb 6th, 01, 06:13 PM Thread Starter
i have an 86 camaro with tpi and my cruise does not work. i think maybe the switch? or maybe a vacuum line.
86camaro is offline
post #2 of 4 (permalink) Old Feb 7th, 01, 06:21 AM
First check the fuse and relay. but
if you have tilt steering, pull the plasic cover off the bottom of the dash, (the fuse box cover is also attached to this. at the base of the Steering column where the t/S and hazard wires and all come out look for the Cruise wire, (mines Orange w white stripe) but yours may be different, check the vacuume area for the cruise solonoid and match up the wire color, (or look in the chiltons manual) many times because of the tilt feature and wandering feet, the wire becomes stretched or cut , I had to re splice mine in order for it to work again on my 91,
hope some of this info helps.
Chris's 67 RS can be seen at http://www.67rs.com
JOIN THE CAMARO NET WEBRING!
Chris Edwards is offline
post #3 of 4 (permalink) Old Feb 7th, 01, 11:11 AM Thread Starter
where is the fuse for the cruise at?
86camaro is offline
post #4 of 4 (permalink) Old Feb 8th, 01, 07:55 AM
the fuse for the cruise is labeld "CT" its a 5 amp fuse (at least on mine, yours may be different, check your fuse panel cover ) located inside the car below the steering wheel/column area , there should be a little door that pops off , the fuses are in there.
