67 AM Pushbutton Delco radio repair - Team Camaro Tech
post #1 of 2 (permalink) Old May 1st, 01, 10:28 AM Thread Starter
My origninal AM pushbutton radio doesn't play. I had removed it from the car some time ago because it didn't work and now I'm trying to repair it. I took the covers and faceplate off and cleaned all the mechanical tuner parts with contact cleaner/lube and all the mechanicals including presets work correctly.
I setup a test bench with the original AM antenae hooked up, a 10 OHM speaker attached, and a battery charger alligator clipped in for power. When the radio is turned on I just get a low hum from the speaker which does not vary when the tuner or volume controls are adjusted. After the radio is on for 10-15 seconds a small amount of smoke starts coming from inside the radio.
Any suggestions on what is usually wrong with these things? I bought another one on Ebay and it has the exact same low hum but no smoke.
Can I buy or find online a repair manual or schematic?
Damon Linkous
'67 Camaro Z21
http://www.linkpro.net/camaro
67_Z21 is offline
post #2 of 2 (permalink) Old May 1st, 01, 01:22 PM
mccorry's Avatar
This may help you out.....
http://cgi.ebay.com/ebaymotors/aw-cg...item=585142358
Granted, it is for a 1969 model...but they may be close....
Steve McCorry - Central Ohio Camaro Club
'69 Camaro RS/SS-350 - Daytona Yellow
'95 Camaro Z-28 - Sebring Silver
click here to see my webpage ---> www.mindspring.com/~mccorry (updated 3/10/01)
[This message has been edited by mccorry (edited 05-01-2001).]
mccorry is offline
