Timing - Team Camaro Tech
post #1 of 3 (permalink) Old Sep 3rd, 03, 01:51 PM Thread Starter
My small block was running awesome!! 350 30over 202 fuelie heads 10:1 solid sig cam 510/ 287. I had set the timing by ear. My buddy checked the advanced timing for me with his ajustable timing light. He said total advanced timing was close to 5000. He took it down to 4000 and said the way I had it would burn the pistons. And now it just doesn't run right. Doesn't sound as good at idle and misses. Book says it should be about 3600 total. Why does it want to run better at much higher advance ?
clayjames is offline
post #2 of 3 (permalink) Old Sep 3rd, 03, 04:11 PM
robert
rolling-robert's Avatar
might be the cam, did u advance or retarded it?
Z28 1984
'77 355ci/COMP cam 218/224 .464/.470 114 LSA
rollerrockers1.5/9.72 forged pistons
ported '66 461 heads 1.94,1.5/Flowtech shorty headers
edelbrock 600/performer rpm intake
th350/shiftkit/hughes2500stall
4th gen 3.23 10 bolt POSI.
rolling-robert is offline
post #3 of 3 (permalink) Old Sep 4th, 03, 06:54 AM
5000-4000-3600-is this RPM or degrees. To check this 1st unhook wac. advance. Use timing light to check timing at idle (12-14* good starting point). Next rev engine slowly to see when mark stops moving. This figure will be your total timing. (example 36* @ 4000 rpm). Sounds like he set it with vac can hooked up-some can have as much as 20* in them-causing your idle timing to be to low. Set it back to your "ear timing" and you should be fine. Your total timing will never be more then idle timing + centrifugal when you are at wide open throttle.
jhow66 is offline
