Weird noise in the rear end. - Team Camaro Tech
post #1 of 9 (permalink) Old Jun 5th, 02, 05:09 PM Thread Starter
About 200 miles ago I had installed a new Richmond 3.73 gears and Caltracs. I noticed a noise coming from the back. It only occurs when I turn, either left or right. it sounds like a "thud-ding sound". I can't really explain the sounds any better. It definately coming from the rear of the vehicle. Could this be from the limited slip on the posi? or the Caltracs?
Thanks in advance.
mikestr is offline
post #2 of 9 (permalink) Old Jun 5th, 02, 05:35 PM
Drive in a circle around a friend.
May help with noise location - rear end - brakes - traction control.
impzilla is offline
post #3 of 9 (permalink) Old Jun 5th, 02, 07:45 PM
mikestr,
Could be that you need more GM additive to the posi. If they don't slip a little they can make a terrible noise when you turn. Mine did and then I put more additive in and the noise went away.
bob spears
69mscle
bspears is offline
post #4 of 9 (permalink) Old Jun 6th, 02, 03:57 AM Thread Starter
<BLOCKQUOTE>quote:</font><HR>Originally posted by bspears:
mikestr,
bob spears
<HR></BLOCKQUOTE>
How/where do I add this posi additive?
mikestr is offline
post #5 of 9 (permalink) Old Jun 6th, 02, 04:45 AM
Send a message via AIM to Spames
If you didn't add any, I would say add 2 small bottles. You add it right were you added the gear lube.
68 Coupe, 350 4-speed
Jim's Camaro Corner
Spames is offline
post #6 of 9 (permalink) Old Jun 6th, 02, 05:27 AM Thread Starter
<BLOCKQUOTE>quote:</font><HR>Originally posted by Spames:
<HR></BLOCKQUOTE>
The two would mix right? I assume that it ok?
mikestr is offline
post #7 of 9 (permalink) Old Jun 6th, 02, 06:19 AM
Yeah, it's just an additive for gear lube. Comes in small (4.oz???) bottles.
Get it at the GM parts counter.
Jim's Camaro Corner
Spames is offline
post #8 of 9 (permalink) Old Jun 6th, 02, 07:54 AM
If you did not use the additive, that is the cause of the clunking. Drive around in a circle or on a freeway off ramp and hear it clunk, clunk, clunk...sort of a "snapping" sound.
Add one bottle, drive around in circles and check for clunking. If you need 2 bottles (I do frequently) add another. That should do it.
-Mark.
stingr69 is offline
post #9 of 9 (permalink) Old Jun 6th, 02, 08:27 AM Thread Starter
<BLOCKQUOTE>quote:</font><HR>Originally posted by stingr69:
-Mark.
<HR></BLOCKQUOTE>
It's definately sounds like a clunking sound, it is certainly evident when, making left/right turns. Is it possible that the guy that did my rear end not put any at all??
Just wondering how much I can add without going over a certain limit.
mikestr is offline
