starting problem - Team Camaro Tech
post #1 of 7 (permalink) Old Jan 18th, 02, 04:05 PM Thread Starter
sam
Sam
Angry
When it's really cold outside my camaro will fire right up. Doesn't matter if it's the first start of the day or repeated starting when goofing off in town. If it's in the 40's or above it seems to crank forever before it starts. new coolant temp sensor, fuel relay, distributor, pickup coil module ,cap, rotor, tps and adjusted, plugs and wires, IAC motor, mass air flow, and starter. 88 iroc 350 tuneport. Don't know what else to look for! Any suggestions?
sam is offline
post #2 of 7 (permalink) Old Jan 19th, 02, 05:54 AM
Have your ignition module (most likely on the inside of the distributor) checked. I had alot of strange problems w/ it, and mostly on warmer days.
wplax26 is offline
post #3 of 7 (permalink) Old Jan 19th, 02, 08:11 AM
ZZ_430's Avatar
Fuel pressure!
If you don't have a good gauge, I'd say get one.
It is the first thing to check!
Don~ ZZ430DropTop
~~~~and~~~~
70 RS/Z28
67 RS/SS Convertible, 70 RS/Z28
ZZ_430 is offline
post #4 of 7 (permalink) Old Jan 19th, 02, 09:33 PM
Z282NV
Guest
Posts: n/a
Smile
85-92 TPI UNITS USES A COLD START INJECTOR AND COLD START THERMO-SENSOR LOCATED NEXT TO THE COOLANT TEMP SENSOR IN FRONT OF THE INTAKE MANIFOLD. IT ALSO HAS 2 WIRES LIKE THE COOLANT TEMP SENSOR AND HAS A SQUARE CONNECTOR W/METAL LOCK CLIP. IT'S POSSIBLE THAT IT MIGHT BE OUT OF RANGE @ 40 DEG. F.AND
ABOVE. USE AN OHM METER( IF YOU HAVE ONE ) TO TEST. A LEAKING FUEL INJECTOR (OR TWO) IS
ANOTHER POSSIBILITY. YOU NEED A FUEL PRESSURE
GAUGE TO DO THIS.
post #5 of 7 (permalink) Old Jan 19th, 02, 09:59 PM
Z282NV
Guest
Posts: n/a
Red face
OOOOPS!! IT IS 85-88 TPI UNITS, NOT 85-92.
MY BAD!!
69 Z28 CLONE(ALL MOTOR 350 11's); 89 5.7 IROC
COUPE; 92 RS w/ B4C PKG. ; 2K2 CAMARO SLP EQUIPPED SS COUPE
post #6 of 7 (permalink) Old Jan 20th, 02, 01:20 PM Thread Starter
sam
Sam
The ignition module is new. It did this with the old one also. The cold start thermo sensor I will check as soon as i can. Fuel pressure is something i know i need to check. But I was wondering how does hot and cold weather affect the pressure? Thanks to everyone for the help and giving me a few more things to go on.
sam is offline
post #7 of 7 (permalink) Old Jan 20th, 02, 05:45 PM
I HAD A PROBLEM WITH MY 89 CAMARRO .SOLENOID WAS BAD . IT WORK FINE IN THE COLD BUT WHEN IT GOT HOT NO GO .IT DOESNT TAKE BUT ABOUT 20 MINS TO RIP OUT THE STARTER TAKE OFF THE SOLENOID AND LOOK INSIDE .MINE HAD SPOTS WHERE IT WAS STICKING CHANGED SOLENOID AND IT WORKS GREAT NOW GOOD LUCK
