What did she do? - Team Camaro Tech
post #1 of 8 (permalink) Old Jan 19th, 02, 11:17 AM Thread Starter
Angry
Hope someone can help.My wife knocked car into neutral with cruise on at about 70.When she got off fwy. car was knocking and running rough.Knocking seems to be from front of block.Any advice or opinions.
Car is a '90 iroc 5.7 auto.
Thanks Turbo
turbo is offline
post #2 of 8 (permalink) Old Jan 19th, 02, 12:34 PM
Hope your setting down, it sounds like it spun a rod bearing or threw a rod thru the side of the engine block.
Branded is offline
post #3 of 8 (permalink) Old Jan 19th, 02, 06:02 PM
the wife did it, huh? yeah, right
355sb, vortec heads, HOT cam,T-10 tranny, 3.70 gears 16X8" IROC wheels
see pics here http://community.webshots.com/user/novaderrik
novaderrik is offline
post #4 of 8 (permalink) Old Jan 20th, 02, 04:37 PM
Lightbulb
Buy her a MSD 6AL with a 3000 RPM rev limit chip,just in case she doe's it again. Do this after installing the new engine.
69 Camaro SS 350 4 speed
86 Monte Carlo SS
gene stills is offline
post #5 of 8 (permalink) Old Jan 21st, 02, 03:13 AM
My cruise control cuts off if I take it out of gear. What really happened.
ryanman250 is offline
post #6 of 8 (permalink) Old Jan 22nd, 02, 12:55 AM
Steven
did you check the dipstick? I am sure you did ... Any oil ??? oil pressure ??? Just oil ??? The cruise control should disengage the moment the rpms shoot up ... did the car overheat ??? What is coolant level like ??? Check every possibility before committing to new engine ...
sdtsdt is offline
post #7 of 8 (permalink) Old Jan 23rd, 02, 04:06 PM Thread Starter
Exclamation
OK SHE BENT SOME VALVES,PUSH RODS.BOTTOM END LOOKS GOOD.
THANKS
turbo is offline
post #8 of 8 (permalink) Old Jan 25th, 02, 07:08 AM
Matt Jones
The pistons that the valves hit may not look too good!
1969 Base Camaro
Vortec 350, TH-400
All sheetmetal is NOS GM
Silver69Camaro is offline
