Engine run on just started????? - Team Camaro Tech
post #1 of 4 (permalink) Old May 29th, 02, 06:13 AM Thread Starter
See Signature for car specs. My car has been running great since last fall. Yesterday she started to diesel on me for the first time ever. I went for a 10 mile ride and shut it off and it ran on for a few seconds and has done it a couple times since then. Now the specs: Timing is set at 14 to 15 with a total of 36 in by 3000, with vacumm advance. We had to crack the secondaries open a tad to get the car to idle good. My carb is 650 double pumper and I have the idle crews turned out about 1 1/8 turns. I had then turned out 1.5 turns but somebody told me turn them in about an 1/8 turn to see if that helps. My car idles at 1000 to 1100 in park and drops down to 750 to 800 in drive. I cant get it to idle below 1000 because the idle screw is all the way out to the point that it doesn't effect it. What should I do? Maybe try closing the secondaries alittle bit more? Could the plugs have anything to do with it. I am using the Resistor 576 Plug from Accel. Should I try the 274 Plug?
68 Camaro RS, Built 355, 274 Comp Cam, Sportsman II Heads 200 c.c. 2.02. Ported to Performer RPM Manifold and 1.75" Headers, 1.5 Roller Rockers, 650 Holley, Steel Crank, 12 Bolt posi with 4.11 Gears, TH350 tranny w/ shift kit.
Erik Beckett is offline
post #2 of 4 (permalink) Old May 29th, 02, 07:08 AM
I would try closing the secondarys just a little then readjust the mixture screws with it idleing around 750 in park until you get the maximum rpm's without moving the idle screw. Then set your idle in drive to a comfortable setting and see what happens.
'69 RS Camaro
355 5-speed 4.11
1 2RUN is offline
post #3 of 4 (permalink) Old May 29th, 02, 07:21 AM Thread Starter
I don't think I can get it to idle down to 750 because it would die when I put it in gear due to the .498 lift cam. Thats the reason we had to open the secondaries a little bit. Thanks, Erik
post #4 of 4 (permalink) Old May 29th, 02, 04:49 PM
I don't know that I would freak out heavy about it. If nothing it could very well be a "bad" batch of gas. Fuels vary considerably from one company to the next. Just food for thought. Scott
psalm69 is offline
