tick tick tick - Team Camaro Tech
post #1 of 4 (permalink) Old Oct 30th, 99, 10:14 AM Thread Starter
I noticed a ticking sound coming from the passenger side of my engine (v8 350). It just started the other day and it sounds like it is coming from the exhaust headers. Would a leak in the gasket cause this to happen?
Scott DiMauro is offline
post #2 of 4 (permalink) Old Oct 30th, 99, 10:37 AM
Larry
Absolutely. Exhaust leaks at the ports or the donut flange tend to be high frequency. You might be sure there isn't a valve tapping. Use the old screwdriver trick at the ear and place the tip on the vavle covers.
Larry
69-er is offline
post #3 of 4 (permalink) Old Oct 30th, 99, 11:22 AM
Could be that the lifter is not pumping up with oil due to a collasped lifter. I had an engine that would tap if the oil was not dead on full.
Joseph
Joseph is offline
post #4 of 4 (permalink) Old Oct 30th, 99, 11:24 AM Thread Starter
THANKS GUYS, HOPEFULLY THESE WILL HELP WITH THE PROBLEM.
