the 700r4 tranny........ - Team Camaro Tech
post #1 of 13 (permalink) Old Jun 1st, 02, 06:08 AM
bigboyp4
Guest
Posts: n/a
well, first i have a '85 camaro ex 2.8l mpfi with a 700r4 tranny. that tranny i had a electric overdrive. i got tired of that engine (it sucked) so i put a 305 in it. ohh man....power! but ne ways i had to get a tranny to bolt up to the v8. i ended up with another 700r4 out of a '91 caprice. i put my v6 700r4 tailshaft on it and it bolted and pluged right in. now heres the question, i want to know how i can get my tranny to shift into overdrive. i have 3 wires coming out of it. i would assume that if i were to give power to one or some of them it would shift but.....i dont know. anyone ever solve this problem without buying a $100 kit. i dont see why i would need the kit if the computer can do it, why cant i? anyinfo would be great.....thanks
post #2 of 13 (permalink) Old Jun 1st, 02, 06:23 AM
it doesn't shift into overdrive electronically, the computer only tells the torque converter when to lock up. i read somewhere- on this site, perhaps- about what parts to buy to make it lockup on it's own without a lockup kit, but can't remember whaere for sure. it was a while ago.
if it isn't shifting into overdrive, you have a problem. the linkage might be out of adjustment, or there is something with the valve body. the tv cable might be adjusted wrong. it might just be starting out in second gear, also. first gear in the 700r4 is pretty steep- almost like the "granny gear" in a truck stick shift tranny. if you are starting in first gear, you will know it.
if the computer is still hooked up and functional, then you might have a bad temp sensor on the engine- it won't lockup the converter until the engine warms up. i just put a temp sensor in my 94 Caprice that was getting crappy fuel economy and not locking up the converter- the $21 sensor fixed that really quick and easy.
355sb, vortec heads, HOT cam,T-10 tranny, 3.70 gears 16X8" IROC wheels. 12" Corvette brakes on the way.
see pics here http://community.webshots.com/user/novaderrik
novaderrik is offline
post #3 of 13 (permalink) Old Jun 1st, 02, 06:40 AM
bigboyp4
Guest
Posts: n/a
im sorry, i meant it wouldnt lock up. the computer is still hooked up but not to an engine. i put a 305 carbed in it so i doubt if the computers gonna lock it up. i just thought that i could apply voltage to some of the wires and make it lock up. thanks
post #4 of 13 (permalink) Old Jun 3rd, 02, 02:22 AM
Send a message via AIM to Spames
If the computer is still in there, and connected to the tranny, you can use the diagnostic plug under the drivers side dash to lock up the converter. I just can't remember which ones you have to jump to lock it up.
68 Coupe, 350 4-speed
Jim's Camaro Corner
Spames is offline
post #5 of 13 (permalink) Old Jun 3rd, 02, 05:07 AM
DjD
DjD's Avatar
My 700r4 came out of an 86 Z and I don't think it was electronicly controled... Give the folks at www.700r4.com a call they can get you going in the right direction. They specialize in helping the do it yourself
...Dennis
"The '69, the '96 & the club"
DjD is offline
post #6 of 13 (permalink) Old Jun 3rd, 02, 03:03 PM
bigboyp4
Guest
Posts: n/a
well, if you would remember the pins on the diagnostic connector that would be awesome, but if u dont, i dont have a good memory so i wont hold it against me. the tranny is out of a 91 caprice, but the origional 700r4 to the car had the same wiring connector, thats how i was able to plug it in. the 700r4 page sells a kit, but i really dont see paying 70 for a kit if i could find a way to lock it up. it seems very possible since theres only 3 wires,not too complicated but im not willing to bust the tranny over it. but ne ways i looked under the car and theres no way i can get the #'s off of it under the car, my exhaust prevents that. well, thanks for the replys, keep em comin
Jeff
post #7 of 13 (permalink) Old Jun 4th, 02, 01:58 AM
Let me try to find it for ya. You don't have a Haynes manual or anything do you? I think there might be a description of the diagnostic plug in there.
Jim's Camaro Corner
Spames is offline
post #8 of 13 (permalink) Old Jun 4th, 02, 01:26 PM
try www.thegrid.net/thedrivetrainpage/700r4.htm
there is information and P/N's for the wiring
TTFN
Mat
Mat Klemp is offline
post #9 of 13 (permalink) Old Jun 5th, 02, 03:14 AM
Do this at your own risk. I've done it on my car to test my converter, and it worked fine for me, but I am unsure if there are any negative reprocussions of doing this. I can only guess that this is essentially what the kits do, but this is a quicker (yet probably less acceptable) method of doing the same thing.
There should be a plug with 12 terminals, each letter below represents a terminal.
F E D C B A
G H _ _ _ M
While you are cruising in over drive, and under light throttle, jump a wire between terminals "A" and "F" above. This should activate the solenoid that locks up the torque converter, provided that the computer is still getting power, and the 4 prong plug that goes into the tranny is connected. What you are doing is grounding the torque converter lock up solenoid (terminal "F") to a body ground (terminal "A").
Let me know what you come up with.
Jim's Camaro Corner
[This message has been edited by Spames (edited 06-05-2002).]
Spames is offline
post #10 of 13 (permalink) Old Jun 5th, 02, 03:30 AM
DjD
DjD's Avatar
The best I can tell about mine is it has 1 wire coming off the 4 prong plug that goes to a batt source that's hot when the key is on.
DjD is offline
post #11 of 13 (permalink) Old Jun 5th, 02, 03:13 PM
bigboyp4
Guest
Posts: n/a
hey, thanks, im going for a drive right now to test it. thanks again
Jeff
'85 Camaro
Ex 2.8l MPFI
305
Edelbrock Intake
Hooker SuperComp Longtube
Mufflex Y pipe
3" Flowmaster Cat-Back that sounds AWESOME
ajracing.cjb.net
post #12 of 13 (permalink) Old Jun 5th, 02, 03:31 PM
bigboyp4
Guest
Posts: n/a
thanks a million spames, IT WORKS! well, im gonna rig up a switch and run it till i dont work, then ill have to buy a kit. but this works, your a lifesaver.
thanks
Jeff
'85 Camaro
Ex 2.8l MPFI
305
Edelbrock Intake
Mufflex Y pipe
ajracing.cjb.net
post #13 of 13 (permalink) Old Jun 6th, 02, 03:16 AM
Good, glad it worked. Just make sure you use it wisely, or you could fry your converter.
Jim's Camaro Corner
Spames is offline
