Tapping noise - Team Camaro Tech
post #1 of 10 (permalink) Old Jan 5th, 02, 09:49 PM Thread Starter
Joe
I've developed a tapping in the #7 cylinder area down low. I can hear it in the block, but not the head or valve cover.
I'm using a piece of tubing to my ear to isolate it.tIt's a light metallic tap, jusy in that area.
Any thoughts? Lifter failing or cam lobe?
Engine is a 396 with hydraulic lifters. Don't know which cam, but it's pretty "lopey".
joe
69 Rat-Infested Resti-Clone
WCA Member
[email protected]
69 Pics http://hobbystage.net/camaro/joeg/index.html
Joe G is offline
post #2 of 10 (permalink) Old Jan 6th, 02, 07:36 AM
I know you said you couldn't hear it in the head, but maybe the rocker arms are too tight?
How old is the motor? (how many miles, i mean)
79 Malibu - 355/th350
83 Camaro - 406 going in, with fireball heads & a real nasty camshaft
JustAGuyWithAFastCar is offline
post #3 of 10 (permalink) Old Jan 6th, 02, 10:20 AM Thread Starter
Joe
Talking
The tapping doesn't seem to be "hearable" in the head or valve cover.
The engine has < 20K miles on it, but it's been driven pretty hard! I like the sound it makes at 5500 rpm!
If it is a lifter failing, can it be replaced? Or does this require new cam, etc.
joe
WCA Member
[email protected]
Joe G is offline
post #4 of 10 (permalink) Old Jan 6th, 02, 10:32 AM
ZZ_430's Avatar
Try pulling the plug wire and see if the noise is reduced.
A wristpin/piston noise would change without load.
Don~ ZZ430DropTop
~~~~and~~~~
Pro-Touring.com DropTop
67 RS/SS Convertible, 70 RS/Z28
ZZ_430 is offline
post #5 of 10 (permalink) Old Jan 6th, 02, 02:42 PM
Thomas
It could be an exhaust leak.
70 1/2 RS Camaro
Slomaro is offline
post #6 of 10 (permalink) Old Jan 6th, 02, 07:02 PM
could be a cracked flexplate.
355sb, vortec heads, HOT cam,T-10 tranny, 3.70 gears 16X8" IROC wheels
see pics here http://community.webshots.com/user/novaderrik
novaderrik is offline
post #7 of 10 (permalink) Old Jan 7th, 02, 07:08 PM
sounds like a spun bearing.
mikenhis69 is offline
post #8 of 10 (permalink) Old Jan 8th, 02, 06:29 PM Thread Starter
Joe
Talking
Thanks for the input. I'll try the spark plug thing.
I'm not sure I follow the cracked flexplate or spun bearing thoughts, tho'.
joe
WCA Member
[email protected]
Joe G is offline
post #9 of 10 (permalink) Old Jan 8th, 02, 07:34 PM
I had a big block that made a light sound like what your describing and it just happened to have been the #7 cylinder and when we tore the motor down the connecting rod had broke right at the base and the piston was at TDC(or close) and their was the lower portion of the rod still bolted on the crank. Don't think thats your problem but mine made the same light tapping noise your describing.
ryanman250 is offline
post #10 of 10 (permalink) Old Jan 10th, 02, 08:49 PM Thread Starter
Joe
Exclamation
Now that's a broken rod! Bet it ran a bit rough.
joe
WCA Member
[email protected]
Joe G is offline
