intermitant problem Help? - Team Camaro Tech
post #1 of 4 (permalink) Old Oct 29th, 01, 09:55 AM Thread Starter
I have a 1992 camaro 3.1 v6. sometimes it just backfires and dies or just wont go. When this happens it runs ok untill you turn the air on but its not the compressor it seems like its related to the switch (electrical) every time I put it in the shop it wont do it.Any help is appreciated Thanks
92 red rs is offline
post #2 of 4 (permalink) Old Oct 31st, 01, 01:57 PM
Joe
Does the check engine light come on at all? If yes then pull then code(s). If no codes check all the connections under the hood and check the grounds too. Also have the charging system checked out. A weak charging system or battery can cause low voltage and make the car run bad when an extra load is added (like the A/C).
Another good idea would be to replace the fuel filter if it hasnt been replaced in a long time. Many times i have seen cars run bad with no real cause and found that a semi bad fuel filter to be the problem.
70 camaro 307 (350soon) /350th
Joekool1234567 is offline
post #3 of 4 (permalink) Old Oct 31st, 01, 02:31 PM
Buddies car acted the same way...Turned out to be a bad alternator..Good luck
Restored 76 LE Trans Am 455 4 speed..# matching
Restored 68 Camaro R/S 327 4 speed
Restored 55 chevy Belair
Blown, Fuel Injected
http://community.webshots.com/user/badcaiman
Badcaiman is offline
post #4 of 4 (permalink) Old Nov 1st, 01, 02:45 AM Thread Starter
I Have no check engine light. Thanks for the info
