700r4 shifting problems - Team Camaro Tech
post #1 of 4 (permalink) Old Nov 2nd, 01, 08:40 PM
rogleete
Guest
Posts: n/a
Just put a B&M quicksilver shifter in the car and it has the 1-2-3-D-R-P shift pattern but when i put it down in 1 it will not hold it, it shifts to 2. but it will hold 2 and 3 wihthout upshifting itself...what could be causing this. shift cable? i dont' see how.
-roger
post #2 of 4 (permalink) Old Nov 3rd, 01, 05:06 AM
DjD
DjD's Avatar
What year car and tranny? Did it do this before the shifter install? I have had 2 chevy trucks ('92 and '96) Both would not stay in first unless you put a load on the engine or put your foot to the floor. I was told it did this by design.
I have a 700r4 out of an '86 iroc in my '69 and it holds 1st fine. It was rebuilt with internal parts from a newer version of the trans but I don't feel that should make a diff...
...Dennis
"The '69, the '96 & the club"
DjD is offline
post #3 of 4 (permalink) Old Nov 3rd, 01, 05:28 AM
Jody
camcojb's Avatar
I believe Dennis is right, many of the stock trannies automatically upshift in first even if you don't shift. I BELIEVE that a Transgo reprogramming kit will eliminate this but I'm not sure.
Transfixleo??????????
Jody
camcojb is offline
post #4 of 4 (permalink) Old Nov 3rd, 01, 09:39 AM
rogleete
Guest
Posts: n/a
I don't know what year it is. but will try to find out. I do know that it doesn't hold first even if you floor it. maybe that kit is the key, i also need to put in an electronic lockup switch. it doesn't have one.
