Need help on starter problem! - Team Camaro Tech
post #1 of 10 (permalink) Old May 24th, 01, 03:12 AM Thread Starter
Lately I've been having problems with the starter on my 89 RS. It seems like when the engine gets to normal operating temperature and then I go to turn it off, I have to wait like 45 mins for it to cool back down. Now I have no clue on starters, I'm a chick and I don't know everything about my new toy so bear with me. I was told that it's the starter seizing up...? But if anyone could help out I'd appreciate it.
BTW.. stock everything... 2.8 V6
Kitten89RS is offline
post #2 of 10 (permalink) Old May 24th, 01, 03:46 AM
Steven
With a name like kitten, we sort of assumed that you were a "chick", but hey, you never know these days... Anyway, give us a little more information, Are you saying (1) the engine turns over very slowly? or (2) The engines turns okay, but never starts or (3) the engine doesn't turn over at all or (4) ???
Give us more information... All electrical problems begin with verifying that you have a good battery and sufficient current. Heat can and does inhibit current flow ... Also, fuel system problems can cause hard starting. Be a bit more descriptive of your car symptoms, and we'll gladly toss some possibilities and suggestions your way . All of us macho car guys love to help "chicks" and "kittens" in distress...
sdtsdt is offline
post #3 of 10 (permalink) Old May 24th, 01, 04:37 AM
Sounds like the dreaded heat soak problem.
68 RS, Ash Gold,pwr brakes,pwr windows,Hounds tooth,355/T350,3200 stall Dynamic converter,3.31:1 posi,Autometer guage pod
CA420 is offline
post #4 of 10 (permalink) Old May 24th, 01, 01:35 PM Thread Starter
Well when this happens, it doesn't do anything. I turn the key and it's just silent. Nothing, nada. But all the electronics work though, heater - radio etc. when I have the key turned forward once but not when I turn it all the way to start it. It acts like the battery is trying to make it turn over but it doesn't. It doesn't make any noise or try to turn over whatsoever. I have a new battery and everything electronical works great except this thing with the starter. Should I get a new one or could it be something more serious? Eek, I hope that helps a lil bit more.
[This message has been edited by Kitten89RS (edited 05-24-2001).]
post #5 of 10 (permalink) Old May 24th, 01, 01:48 PM
ZZ_430's Avatar
Kitten you could solve that problem with a mini starter from summitracing.com It's about $150 it's a high torque starter that NEVER fails to start our cars. check it out! PS obviously the cables etc. need to be good too.
ZZ_430 is offline
post #6 of 10 (permalink) Old May 24th, 01, 03:22 PM
Talking
Kitten:
I had the same problem with my 1980, with a 350 in it. It had headers put in it and came really clase to the starter. This cause a heat soak condition and would barely turn over when the car was hot. I bought a starter heat sheild blanket from Summit for 20 bucks or so and installed it and havent had a problem at all since. i would try this before i shell out 150 for a new starter. GOOD LUCK
Nate
eggersn is offline
post #7 of 10 (permalink) Old May 24th, 01, 04:00 PM
Steven
Kitten, it sounds like the heat is taking a toll on your starter. If it is the original starter, you may be fine with just a regular replacement. You are not running a high compression modified kind of engine, so you shouldn't have any special requirements...the heat shield certainly wouldn't hurt, but if it is the original starter, replace it. Also, if the battery cables are original, go ahead and replace them also at this time. Last but not least, make sure that you have sufficient coolant in the radiator and that the car is not running hotter that it suppose to be ... watch your temperature gauge... is your fan functioning properly to cool the engine? Just things to consider...
sdtsdt is offline
post #8 of 10 (permalink) Old May 24th, 01, 04:51 PM Thread Starter
Thanks guys you helped me out alot!
It doesn't do it anymore! Woo hoo!
post #9 of 10 (permalink) Old May 25th, 01, 09:34 AM
Steven
please post what corrective action you did to resolve the problem ... glad to hear that you are driving happily now ...
sdtsdt is offline
post #10 of 10 (permalink) Old May 25th, 01, 12:30 PM Thread Starter
Well,
I took your advice and got myself a heat shield. That worked great.
