Knocking - Team Camaro Tech
post #1 of 4 (permalink) Old Oct 21st, 01, 02:22 AM Thread Starter
Im hoping you guys could give me a few suggestions about what this might be.....
Inside the car it sounds like im getting a mettallic ringing noise upon acceleration and sometime decceleration. It doesnt occur when i start the car up...it happens after i started driving or revving the engine. The noice isnt consistent with rpm though. Then when i was outside the car reving it to check the timing i noticed that the ringing noise sounds like a knocking coming from the pass. side rear of the motor. Oil pressure is fine, no smoke out the exhuast, oil isnt black, spark plugs all look clean....WHAT THE HELL IS CAUSING THIS!!!! One person suggested i check the torque converter bolts, i still have to check those out but are there any other suggestions just in case?
jvolk81 is offline
post #2 of 4 (permalink) Old Oct 21st, 01, 08:01 AM
Yes, Torque converter bolts loose make a strange ringing sound. Also, a cracked flexplate..
-gary
cavemate is offline
post #3 of 4 (permalink) Old Oct 21st, 01, 10:56 AM Thread Starter
Ill have to inspect the flexplate then because i just torqued the crap out of the bolts and its still doin it.
http://www.ofoto.com/SlideshowSummar...8331103&state=
jvolk81 is offline
post #4 of 4 (permalink) Old Oct 23rd, 01, 01:11 PM Thread Starter
damnit, i spent 5 hours replacing my torque converter (dont ask y it took so long) luckily i had a 3200 stall layin around...the bad new is the noise is still there and i think its the tranny
jvolk81 is offline
