IGNITION KEY WITH CHIP - Team Camaro Tech
post #1 of 4 (permalink) Old Oct 11th, 01, 02:06 PM Thread Starter
I have a 89 camaro with the dum design with the key in the chip. I have it all tore down to get my ignition out . Is there any waty to buy pass the sensor. So that it will start without the chip. MIne is broke and to repalce i is 90$ I would rather put the money into my motor instaed.. If any one has done this Please let me know.
thanks kevin
KEVY G is offline
post #2 of 4 (permalink) Old Oct 12th, 01, 01:06 AM
Cool
You have the Pass Key system to prevent theft.
The way to do it is you insert the key, try to start, and nothing happens. Wait 3 minutes, with same key, it should start.
You can buy just the tumbler set and this will include a new chip socket and a new key. If your real nice to the parts man at the dealer, he might cut you two extra keys. Be sure to take your original key for comparision so as the dealer can give you the correct chip in the key. Any GM dealer can do this,
I did this to a friend's Cadillac and it cost me a total of $50.
post #3 of 4 (permalink) Old Oct 12th, 01, 01:31 AM
Check this thread:
https://www.camaros.net/forum/Forum10/HTML/000716.html
Mark Canning
1969 Indy Pace Car
350/300HP RPO Z11
My 69 L48 - 350/300HP Engine
Mark C is offline
post #4 of 4 (permalink) Old Oct 14th, 01, 03:56 PM Thread Starter
Thumbs up
Ok went to a car show yesterday, And there was a guy who had a 92 rs with a 3.1`v6.
He switched it to a 355 very nasty cam in it. I ask him about the chip and he said he by passed it. Havent tried it yet but he said. Unplug wire the 2 yellow wires are to the ignition at the bottom of the colum. Unplug and cut it take your old key with the chip and sorder it one wire on each side of the chip. Put another ignition in or youse your old one and it finds it signal and stars up. Sounds to good to be true ill will try it tomorie .. Has any one tried this before.
KEVY G is offline
