Fuel line leak - Team Camaro Tech
post #1 of 6 (permalink) Old Apr 17th, 13, 09:24 PM Thread Starter
Dan
Fuel line leak
Ok, I am stumped. I had a carb for my 69 Z28 (302) rebuilt and installed it on my 68 Z28 (302) while the 68 carb was out getting rebuilt (same person) the 68 had not run for 30 years, got it running just fine. Received the 68 carb back and swapped them out to have the correct date coded carb on the correct car. And now the carb on the 68 leaks at both lines into the carb at the carb.
I have looked at the flares and the seats and see nothing!
Any thoughts?
69 LeMans Blue X77 Z28 (SOLD)
68 Corvette Bronze RS Z28
68 LeMans Blue SS 396 L78 (9978 orig miles)
DDZ28 is offline
post #2 of 6 (permalink) Old Apr 18th, 13, 04:18 AM
Re: Fuel line leak
Visit your local hydraulic & pneumatic hose shop and get a couple copper crush washers for the flares.
Snug the fittings and problem gone.
post #3 of 6 (permalink) Old Apr 18th, 13, 05:50 AM Thread Starter
Dan
Re: Fuel line leak
Thanks, I will give that a try.
DDZ28 is offline
post #4 of 6 (permalink) Old Apr 18th, 13, 07:10 AM
Re: Fuel line leak
Another trick you might try before you go,
Apply a drop of oil on the back side of the tubing flare, then slide up the nut and tighten.
Oil can be from engine dipstick.
post #5 of 6 (permalink) Old Apr 19th, 13, 09:16 PM
Re: Fuel line leak
The fuel inlet nuts thread into the carb float bowls. The fuel line flare fittings thread into the fuel inlet nuts. There should be a steel gasket between each fuel inlet nut and the float bowl. If they are missing that is the cause of your leaks. http://www.summitracing.com/parts/hly-108-8
BPOS is offline
post #6 of 6 (permalink) Old Apr 20th, 13, 07:44 AM Thread Starter
Dan
Re: Fuel line leak
Thanks for the reply's. The washers mentioned are not missing so that was not the issue.
I live in a foothill community and trying to find copper crush washers is impossible but after a little memory loss return I realized that the copper crush was the same item I use in my industry (refrigeration) and we call them flare bonnets. Dug around the shop and found a box of them. Put them in and no more leaks.
Thanks for jogging my memory Everett#2390.
This allowed me to get my Corvette Bronze 68 Z/28 RS running and drive it around a little. it had not run for 30 years.
Thanks again
DDZ28 is offline
