'69 SS 350 problems - Team Camaro Tech
post #1 of 5 (permalink) Old Sep 27th, 99, 04:55 PM Thread Starter
When I step on the gas it pauses for about 1-1/2 sec then kicks in hard..sometimes it completely stalls out during this 'pause' when in 1st gear. And also it stalls just sitting at stop lights, any advice? what could lead to this?
if i change the idle screw (more rpm's)..does it throw timing off?
[This message has been edited by Leeter (edited 09-28-99).]
Leeter is offline
post #2 of 5 (permalink) Old Sep 27th, 99, 05:29 PM
Two things come to mind....possible accelerator pump in the carburetor bad, or the timing is not set right. Could be the vacuum advance can is bad, not giving the additional timing you need at idle.
Dave Birdwell is offline
post #3 of 5 (permalink) Old Sep 29th, 99, 06:01 PM
Bryan Shook
I agree w/ Dave on the accerator pump, the diaframs do go bad, but what it seems like to me is your fuel level in the bowls, maybe a float is sticking or something.
elcamino72 is offline
post #4 of 5 (permalink) Old Sep 29th, 99, 06:01 PM
Bryan Shook
Bryan Shook
Burgettstown, Pa
post #5 of 5 (permalink) Old Sep 30th, 99, 12:38 PM Thread Starter
Thanks guys...i checked it out and took off the carb, opened up the accelerator pump and it had a layer about 1/5" thick sand in it along with a butt load of corosion and pit marks...I got a new bowl coming in tomarrow!
Leeter is offline
