vibration from drive line - Team Camaro Tech
post #1 of 6 (permalink) Old Feb 15th, 01, 12:50 PM Thread Starter
Red face
bad vibration, comes up from the gear shifter and the rear end. started off just when you let off the throtle at about 85. Now it is a constant vibration from 70mph and up. The vibration gets worse as you go up. The car is a 1995 z28. i have replaced both u-joints, had the drive shaft ballanced and the tires ballanced. Please help.
[This message has been edited by RSBell11 (edited 02-15-2001).]
RSBell11 is offline
post #2 of 6 (permalink) Old Feb 15th, 01, 02:15 PM
My guess would be universal joint?
kz1000ltd is offline
post #3 of 6 (permalink) Old Feb 15th, 01, 08:42 PM
it can also be caused by a bad slip joint. if you have too much play in the slip joint it will do this.
ilbl8 is offline
post #4 of 6 (permalink) Old Feb 16th, 01, 09:00 AM
Even though you've replaced the u-joints and had the shaft balanced, check the shaft in the car. Get the back end in the air, with good jackstands under the rear and run it in 1st gear and watch the driveshaft real close.
BIGDOG454 is offline
post #5 of 6 (permalink) Old Feb 21st, 01, 07:03 AM
Angry
Did you ever figure it out?if so please E mail me.My 1992 camaro does the exact same thing to the tee. Ive contemplated getting my drive shaft balanced.BY the way how much does that cost ??I would appreciate some feedback im about ready to start launching tools!!!!
gmcie2001 is offline
post #6 of 6 (permalink) Old Feb 21st, 01, 12:36 PM
On your 92 it could be your rear trans mount. I have broke many on mine before and it will give you vibration.
camaroguy is offline
