No fuel to the carb... - Team Camaro Tech
post #1 of 12 (permalink) Old Mar 30th, 03, 01:22 PM Thread Starter
Ok, what would be the cause for this...upon cranking the engine, I am not getting fuel to the carb. I have a new clear view filter no gas is in it.Yes, I do have gas in the tank. Dan
'67 Camaro rs, L30-327/275.
no bail4u is offline
post #2 of 12 (permalink) Old Mar 30th, 03, 02:07 PM
Kevin
Eliminate the possibilities. Do you have fuel from the pump to the filter? If not, do you have fuel to the pump? If not check to see if you have fuel from the tank. If none from the tank than you might have a obstructed tank filter. If none to the pump, than you could have a kink or clogged line. If no fuel to the filter than check your pump. You may have already checked this stuff but it is always good to have an outside reminder. Is this a new engine? Rhat.
KRhat is offline
post #3 of 12 (permalink) Old Mar 30th, 03, 03:02 PM Thread Starter
Thanks KRhat...Do mechanical pumps just fail ? That is where I am leaning towards but never had one just quit.
post #4 of 12 (permalink) Old Mar 30th, 03, 03:06 PM Thread Starter
I just pulled the line from the inlet of the fuel filter, the line leads right to the pump.I turned the motor over and it should have gushed fuel, but not a drop. How can a mechanical pump fail ? Dan
post #5 of 12 (permalink) Old Mar 30th, 03, 03:15 PM Thread Starter
Just for the mention, this pump may be the original '67. The car is very original throughout. I have owned the car for 2 years. I drove it to many shows during the spring and summer. She sits the winter , but I do fire her up from time to time. A mechanical fuel pump seems so basic to fail. Not much there to worry about. It's got me dumb founded. Dan
post #6 of 12 (permalink) Old Mar 30th, 03, 03:29 PM
KRhat has it right. You've either got an obstructed fuel line or a dead pump. You can remove the supply line and rig it to run off a gas can; if it pumps fuel from the can, your line is obstructed. If not, your pump is no good.
William
Pair of 68 projects. 350 4 spd, 454 4 spd.
Ratchetman454 is offline
post #7 of 12 (permalink) Old Mar 30th, 03, 09:10 PM
I've seen the stamped metal arms that drive the pump just crack leaving no leverage to the pump to get it going. Some things just break.
Snatchin'gears is offline
post #8 of 12 (permalink) Old Mar 30th, 03, 10:32 PM Thread Starter
Amen to that. I'll pull it today and take a look. Thanks to all of your responses. This is one heck of a site ! [img]graemlins/thumbsup.gif[/img]
post #9 of 12 (permalink) Old Mar 31st, 03, 03:54 AM
robert
rolling-robert's Avatar
when i rebuilt my v8 with mechanical pump i had the same problem, when i used a can of cold start(the one u spray directly in the carb)it pumped up a little fuel.
so i filled the carburator with fuel by my self and now it runs perfect.
maybe just cranking the engine isnt enough for the fuelpump to suck up fuel.
Z28 1984
'77 355ci/COMP cam 218/224 .464/.470 114 LSA
rollerrockers1.5/9.72 forged pistons
ported '66 461 heads 1.94,1.5/Flowtech shorty headers
edelbrock 600/performer rpm intake
th350/shiftkit/hughes2500stall
4th gen 3.23 10 bolt POSI.
rolling-robert is offline
post #10 of 12 (permalink) Old Mar 31st, 03, 05:49 AM Thread Starter
Thumbs up
I'll try that before I remove it. Thanks , Dan
post #11 of 12 (permalink) Old Mar 31st, 03, 03:12 PM Thread Starter
Thumbs up
Strange but True...a shot of starting fluid got the damned thing going again. Wierd.
post #12 of 12 (permalink) Old Apr 1st, 03, 05:19 AM
robert
gee, i actually helped someone out... wow!
my first time [img]graemlins/hurray.gif[/img]
Z28 1984
