ODBII - Team Camaro Tech
post #1 of 7 (permalink) Old May 14th, 01, 11:57 AM Thread Starter
Will the ODBII service engine light go out if the problem is fixed, or does it need to be reset.Problem was an O2 sensor. I changed it.
1996 Camaro V6
mindless06795 is offline
post #2 of 7 (permalink) Old May 14th, 01, 03:47 PM
usally you will have to reset,either pull ecm fuse or dissconnect batt for a couple of minutets
the mechanic is offline
post #3 of 7 (permalink) Old May 14th, 01, 03:55 PM
ZZ_430's Avatar
you may have to clear using scanner.
ZZ_430 is offline
post #4 of 7 (permalink) Old May 14th, 01, 04:09 PM Thread Starter
<BLOCKQUOTE>quote:</font><HR>Originally posted by the mechanic:
usally you will have to reset,either pull ecm fuse or dissconnect batt for a couple of minutets<HR></BLOCKQUOTE>
Do you know where the ECM fuse may be?
post #5 of 7 (permalink) Old May 14th, 01, 05:23 PM
it should be in fusebox not sure what it may be labeled(check owners manual?),did you try disconnecting batt. power,if so does code go away for any time at all?
post #6 of 7 (permalink) Old May 14th, 01, 05:25 PM Thread Starter
it should be in fusebox not sure what it may be labeled(check owners manual?),did you try disconnecting batt. power,if so does code go away for any time at all?<HR></BLOCKQUOTE>
Well, first of all, do you know if the P0133 codes means to change the 02 sensor?
post #7 of 7 (permalink) Old May 14th, 01, 07:24 PM
Talking
ill check and get back to you asap!!!
