Starting Troubles - Team Camaro Tech
post #1 of 4 (permalink) Old Jun 19th, 01, 07:45 PM Thread Starter
I have a '67 camaro with a mild to moderate 327. I am having a starting problem, lots of fuel with new AC Delco electric pump but no spark. The distributor is brand new, it has an MSD under the cap coil. The cap and rotor are also new. There is power at the BAT connection. Anybody with an idea as to what else I can check. It doesn't get much simpler than an HEI setup so I'm stumped. Any help would be appreciated.
thillman is offline
post #2 of 4 (permalink) Old Jun 20th, 01, 12:59 AM
Cool
Disassemble the coil/cap, Makes sure the grd wire is tied in with the coil holddown screw.
Check also for the spring(?) between the coil output and the cap's spring-loaded center conductor going to the rotor.
If you have an original HEI distributor, then buy a cheap replacement module and subsitute for the MSD, just to see if it runs, could be MSD is broke.
post #3 of 4 (permalink) Old Jun 20th, 01, 10:42 AM Thread Starter
Thanks Everett
This is a brand new distributor, the old one didn't work either. Its an MSD coil that worked before I disassembled it to install a new intake. Whats the best way to test the coil?
thillman is offline
post #4 of 4 (permalink) Old Jun 21st, 01, 01:29 AM
Cool
HEI coil? Measure primary and secondary resisitance with a Digital Voltmeter, Pri=<30 ohms, Sec = 10k-15k ohms.
Everett
