Engine stalls during deceleration... - Team Camaro Tech
post #1 of 5 (permalink) Old Sep 17th, 03, 09:28 AM Thread Starter
I have a '73 z/28. Pretty simple components: 350, TH400, Holly 750. If I step on the brakes and decelerate quickly, the engine will die. I can immediately knock it into neutral and start the engine afterwards. Anyone experienced this one before or have any input?
Thanks...
vman2112 is offline
post #2 of 5 (permalink) Old Sep 17th, 03, 12:37 PM
Royce
Check your float level. If it is too high fuel will block the vent during breaking (or slosh out of the vent into the carb).
Royce (NO XQSSS) Bradley
camaroman7d is offline
post #3 of 5 (permalink) Old Sep 18th, 03, 02:16 AM
TRT
I had this same problem when I had my vacuum advance disconnected.
Re-connected the vacuum advance and the problem was cured.
The voice of dissent
TRT is offline
post #4 of 5 (permalink) Old Sep 19th, 03, 09:38 AM Thread Starter
Thanks guys... I'll check on both of those possibilities.
vman2112 is offline
post #5 of 5 (permalink) Old Oct 24th, 03, 07:20 PM
Cool
I'd also check for your kickdown cable. Your situation is common on automatics, hence why they put in the kickdown cables. I've only worked on a 350 but would suggest something might be binding near your carb
az57chevy is offline
