2002 Camaro no-start/run condition - Team Camaro Tech
post #1 of 6 (permalink) Old May 12th, 13, 04:49 PM Thread Starter
Robert
Question 2002 Camaro no-start/run condition
Have a 02 camaro, 3.8L. It also has an aftermarket Viper alarm system but it seems to be functioning properly. I scanned the car and came up with a trouble code, I believe P1609(?) Essentially the security system(factory) disabling the fuel system, But the car will not turn over either. I jumped the starter relay and the car starts and runs for 2-3 seconds and dies, if I spray carb cleaner in the intake it will keep running, so it is losing fuel and start capability. The security light on the dash keeps flashing.I called the dealer ship and they said the factory security disables the fuel system and possibly also has a starter inter-lock. I have no idea where the security module is or how to go about testing it or totally disabling it. I took the cars ignition key to the dealer and they tested it in their machine so the key is not the issue. Because of this I don't believe putting a resistor in-line to bypass the key would do any good. The starter and fuel pump relays are both good. All fuses checked and good.
I could really use some help with this as the lady that owns the car has to have it to get to work and doesn't have much money. I'm trying to help but this is not in my area of expertise. Any help would be much appreciated.
carman67 is offline
post #2 of 6 (permalink) Old May 12th, 13, 04:55 PM
Re: 2002 Camaro no-start/run condition
Best guess the lock cylinder/pass key, is bad. Take your key read the reaistance, Then under dash, there is a wire down the collum, orange, two tiny wires, disconnet the plug, measure the resistance, between the two white wires, with key in cylinder, The restiance shoud be the same.
john68 is offline
post #3 of 6 (permalink) Old May 12th, 13, 05:09 PM
The tumbler in the column will need replacing, proof of ownership at any GM dealer, the original key , and steering wheel has to come off along with combo switch handle.
She can start the car with the original key after waiting min 3 minutes from the initial start and use the same key to start again. VATS kills the starter relay and fuel system, ie, fuel pump.
Or as John suggests, measure the resistance of the key chip, get a resistor of the next higher value, then use a file to lessen the amount of resistance to match the key. Then unplug the column wires from the connector and insert the resistor into the connector going out to the module, under the glovebox or pass kick panel.
Doing a good job is like peeing in your dark pants you get a warm feeling, but nobody notices
Everett#2390 is online now
post #4 of 6 (permalink) Old May 12th, 13, 06:28 PM
Steiner
Or just contact any of your friendly neighborhood tuners and they can just disable VATS in your PCM for $50. You should be able to find one that lets you take it out and bring it to them.
'69 Camaro
500hp/538lbft
Steiner is offline
post #5 of 6 (permalink) Old May 14th, 13, 09:34 AM Thread Starter
Robert
I really appreciate the help. I did as you suggested and unplugged the harness under the column and did an ohm's test and came up with nothing. It is a #9 key so 3,010 ohm's and Radio shack only sells 3.3k so I bought a package of 1.5k's and soldered 2 of them in series for my 3k. Tapped them in-line, with the ignition left unplugged and the car started right up. I thank you all for the assistance.
carman67 is offline
post #6 of 6 (permalink) Old May 14th, 13, 06:45 PM
Cool! Now you know where the problem is residing.
