Starter problem - Team Camaro Tech
post #1 of 5 (permalink) Old Mar 12th, 02, 09:47 AM Thread Starter
When I tried to start my 67 today all I heard was a big whirring sound and the engine didn't crank at all. When the starter does this is it usually a hint that its time to be replaced? I also have a drain in my electrical system that I've yet to find. Sometimes when I turn the key nothing happend at all and the generator light comes on. The alternator, voltage regulator, ignition switch, coil, and battery are brand new. What do you guys think?
shadow53 is offline
post #2 of 5 (permalink) Old Mar 12th, 02, 01:39 PM
for the starting issue, what about Neutral saftey switch..
as far as current drain, make sure all your accessories are off, (like your aftermarket sterio and amps etc.. ) then verify you (if you have it) hooked up the HEI properly, the BATT side doesnt mean forever current, only +12v when the key is on.. a good test is if you disconnect the battery on the - side, and just touch it, it should not "pop" or show a spark like current, if so you have a current draw... get a test light and start testing fuse panel circuts
Chris's 67 RS/SS,can be seen at http://www.67rs.com
check out another site once in a while! http://www.fbodyconnection.com
Chris Edwards is offline
post #3 of 5 (permalink) Old Mar 12th, 02, 01:44 PM
Bob
Could be the bendix on the satrter spinning but not kicking the gear in.
Bob
Garnet Red 69/SS396/TH400/355 Posi
94 HD Dyna Wideglide
phel69 is offline
post #4 of 5 (permalink) Old Mar 13th, 02, 06:59 AM
Send a message via MSN to kausboy
Sounds like the solenoid in the starter has issues! When you turn the key the solenoid it activated pulling in the starter drive and sending power to the starter and ignition system. For some reason the contacts in the solenoid arn't contacting correctly --my guess is the fork and lever that actuate the starter drive is wore out or the contacts in the solenoid. Either way it is in the solenoid!
kausboy is offline
post #5 of 5 (permalink) Old Mar 13th, 02, 10:59 AM Thread Starter
New starter=No more problems. Thanks guys.
shadow53 is offline
