91 Camaro Braking problems...need help - Team Camaro Tech
post #1 of 5 (permalink) Old Jan 13th, 01, 08:36 PM Thread Starter
During hard braking stops my car pulls hard to the right. I have disc in front/Drums in rear. I have replaced the rotor, pads, drum, and shoes to no avail. Please Help!
Thanks!
Matt
91 RS 305 TBI
Matt E is offline
post #2 of 5 (permalink) Old Jan 14th, 01, 04:38 AM
You may not have a brake system problem...you alignment could be off, you might have a tire going bad (cords seperating) or possibly a worn steering/suspension component. Also, make sure your wheel bearings are adjusted correctly...if one side is set tighter than the other, then that brake will "kick in" before the other does.
375hp 78 Chevy truck
77 Chevy Nova
95 Chevy Lumina 3.4L
and building a 78 Nova
travis is offline
post #3 of 5 (permalink) Old Jan 14th, 01, 07:01 AM
William
William's Avatar
My '89 did this until both front brake hoses were routinely replaced during a suspension rebuild. Do the rear also while you're at it.
William is offline
post #4 of 5 (permalink) Old Jan 16th, 01, 04:06 PM
sounds like the left front flex hose to me
drews70camaro is offline
post #5 of 5 (permalink) Old Jan 17th, 01, 10:29 AM
your brake hoses are bad. they may not look it, but they are collapsing in on themselves internally, I went through all the same headache, new rotors, calipers, pads, blah blah blah, If i would have just spent the 16 bux to replace the hoses I could have saved alot of money...
Chris's 67 RS can be seen at http://www.67rs.com
JOIN THE CAMARO NET WEBRING!
Chris Edwards is offline
