Power Top is Dead - Team Camaro Tech
post #1 of 2 (permalink) Old Jun 17th, 01, 12:57 AM Thread Starter
Unhappy
I am looking for advise on diagnosing what is causing my 1968 convertible power top to not function. I can get very, very slight movement from it when I hit the switch.
Is it the pump motor, hydraulic oil level or what? I was hoping for some guidance before I start to rip into it piece by piece.
The top is stuck in the full down position.
68bbconv is offline
post #2 of 2 (permalink) Old Jun 17th, 01, 05:21 PM
Gary
Is the pump actually working? If so, I would check the fluid level in the pump. The level should be even with the filler hole. It sounds like the level is down. Try this first.
Gary Dorion is offline
