Hardly starts when engine is warm! - Team Camaro Tech
post #1 of 7 (permalink) Old Nov 30th, 01, 04:55 PM Thread Starter
Unhappy
Fella's
Once my engine reaches cruising temps (180-200) in my Big Block it will hardly start. It acts like the timing is too far out but it isnt. It runs like a scalded dog and when I first start it (cold) it cranks right up! when it warms up it hardly turns over but still runs fine once it does kick over. I have a New battery, new starter and new cable. Any sugestions?
Thanks.
396 cid is offline
post #2 of 7 (permalink) Old Nov 30th, 01, 07:08 PM
XK1
Hot starter??
76 Camaro/mild 350 .030/M21/Z28 body parts/lotsa other goodies
XK1 is offline
post #3 of 7 (permalink) Old Dec 1st, 01, 05:41 AM
Unhappy
Notorious Chevy Big Block problem..There are no direct cures since it could be many things. I assume your timing is correct..Also, what is the CCA of the battery? You should have at least 750 CCA. The cables must be real good ones. No whimy deals.. Get heavy cables to accept the heavy loads of a hot engine/starter. Lastly, install a heat shield around the starter. Theyre avail aftermarket. If you have headers,insulate the started real well!..That's all I can say. Good luck
-Gary
cavemate is offline
post #4 of 7 (permalink) Old Dec 1st, 01, 09:43 AM
The above quotes are good but to be sure it's not over advanced timing pull off coil wire and ground it then crank engine over.If it now spins over normal the timing is too advanced for starting.
[This message has been edited by sschevyfan (edited 12-01-2001).]
sschevyfan is offline
post #5 of 7 (permalink) Old Dec 1st, 01, 07:37 PM
Best way to fix this problem is to put a remote starter sol. on it. Mad makes a kit just for this or make your own.
jhow66 is offline
post #6 of 7 (permalink) Old Dec 1st, 01, 08:22 PM
Joe
Ive found that those mini starters work well. Ive installed two, one on a big block camaro that had a starter noise and one on a big block chevelle that was hard to start when hot. On both the mini starters fixed the problems. The chevelle kept going through starters because the header was to close, even with wrap and heat shield it would heat soak the starter.
70 camaro 307 (350soon) /350th
Joekool1234567 is offline
post #7 of 7 (permalink) Old Dec 1st, 01, 09:55 PM
what kind of a starter? is it a hi torque one, or a tiny small block one? a big starter might be needed if you have a healthy motor, or an aftermarket mini starter. also, use the biggest cables you can get(or make).i like 00 gauge arc welding cable for battery cables. you'd be amazed what a difference cables can make. how big is the battery? i know i am repeating what others have said, but cover the basics. just taking off and re-connecting the battery cables can make a difference.
355sb, vortec heads, HOT cam,T-10 tranny, 3.70 gears 16" IROC wheels
novaderrik is offline
