power-steering fluid... - Team Camaro Tech
post #1 of 2 (permalink) Old May 10th, 03, 07:27 AM Thread Starter
robert
rolling-robert's Avatar
i used brake-fluid in my power-steering reservoir, is that a problem?
Z28 1984
'77 355ci/COMP cam 218/224 .464/.470 114 LSA
rollerrockers1.5/9.72 forged pistons
ported '66 461 heads 1.94,1.5/Flowtech shorty headers
edelbrock 600/performer rpm intake
th350/shiftkit/hughes2500stall
4th gen 3.23 10 bolt POSI.
rolling-robert is offline
post #2 of 2 (permalink) Old May 10th, 03, 02:33 PM
Unhappy
I think its a proplem. I'm not sure, but I dont't think those two fluids are interchangeable. If I were you I would flush the system. I just flushed my PS system by jacking up the front tires off the ground, disconnected the PS pump belt, and disconnected the PS return line at the pump. Then turn the pump pulley with a drill and a 7/8 socket and keep adding fluid. I had a friend turn the wheel from side to side while I added fluid and turned the pulley. Figure on using about 2 quarts. Its quick work.
67 RS Convertible, 355ci, 650cfm, 5-speed, 12-bolt, 3.90 gears. 12.7 @ 110 mph
Marktat is offline
