wiper problems? - Team Camaro Tech
post #1 of 7 (permalink) Old Jan 4th, 01, 12:05 PM Thread Starter
kp
Unhappy
its a 69 camaro,wipers do not work at all.all wires to the wiper motor are hot,but wiper motor still doesnt run.i have install a new motor and wiper switch?any help appreciated!
kp is offline
post #2 of 7 (permalink) Old Jan 4th, 01, 12:52 PM
Talking
Sounds like a bad ground.
wrench turner is offline
post #3 of 7 (permalink) Old Jan 5th, 01, 10:52 AM
<BLOCKQUOTE>quote:</font><HR>Originally posted by wrench turner:
Sounds like a bad ground. <HR></BLOCKQUOTE>
Mine dont work either. the people I got my car from robbed the power for my HEI ignition from the plug at the wiper motor. I reconnected it but no good. Just thought i'd ask how is the motor grounded? I'll check mine for propper ground. thanks
HOTROD69CAMARO is offline
post #4 of 7 (permalink) Old Jan 5th, 01, 10:56 AM
Where is the wiper moter grounded on a 69
post #5 of 7 (permalink) Old Jan 5th, 01, 12:01 PM
David Pozzi
davidpozzi's Avatar
I think one of the three mounting screws has a metal tab to go from the wiper body to the attachment screw. Otherwise the rubber grommets insulate the wiper so, no ground.
Almost all GM wipers are this way.
David's Motorsports page
First Gen Suspension Page
67 RS 327
69 Camaro Vintage Racer
davidpozzi is offline
post #6 of 7 (permalink) Old Jan 5th, 01, 02:28 PM
Talking
This is a simple fix. On the front of the motor on the flat part there are a few small holes. Using a self tapping screw and wire connecters run a wire from one of these holes to the cars body.
post #7 of 7 (permalink) Old Jan 6th, 01, 09:08 AM
JohnZ's Avatar
The '69 wiper circuit is grounded at the wiper switch through a stamped sheet metal ground strap that's shared with the light switch - the bottom leg of it attaches to the lower metal instrument panel reinforcement, same screw that has the black instrument cluster ground wire under it. Make sure the strap is there, sandwiched under the wiper switch, and it's properly attached at the bottom.
JohnZ
'69 Z28 Fathom Green
JohnZ is offline
