78'chevy truck is running badly - Team Camaro Tech
post #1 of 7 (permalink) Old May 20th, 02, 12:26 PM Thread Starter
my problem is now my 78'chevy truck with a 350 is running badly. it all started when i removed my HEI distributor to see if it would make my camaros engine because it was missing at idle, so anyways i put my trucks distributor back in and i fired it up and and try to set it at 8 degrees. but the engine ran rough and some time would die,so i thought i had a vacuum leak i thought it was the intake manifold gasket, so i replaced it. also when i had the carb off i cleaned it up since i had it off. i put every thing back in place and tryed to fire the engine up and i set the timing once again at 8 degrees still it wanted to run really rough,so i thought it was maybe the spark plugs sinc i have not changed them since almost 2 years ago so i put some new plugs and a new ditributor cap and rotor since it looked worned out, and also i put some WD40 one the advance weights ,becaus they look a little rusty i moved them around to see if they where stuck and worked some more WD40 in so free the advance weight up. i put all the parts togeter and still the engine runs rough, it sound like a tractor or a diesel. when i advance it by alot , it will sound like it should and runs smoother, but i know it should not be that advance at idle.
now I'm out of ideas any suggestions would be greatly appreciated
72'camaroguy is offline
post #2 of 7 (permalink) Old May 20th, 02, 01:59 PM
72,
If the truck ran good before you pulled the dist. and bad after you put the dist. back in, my first thought would be that the distributor shaft is rotated a tooth or two off of it's original orientation. Maybe you just need to pull and reinstall.
street is offline
post #3 of 7 (permalink) Old May 20th, 02, 02:05 PM
72,
If the truck ran good before you pulled the dist. and bad after you put it back in, my first thought would be that the distributor shaft is off a tooth or two from it's original orientation. Maybe you just need to pull and reinstall.
street is offline
post #4 of 7 (permalink) Old May 20th, 02, 05:38 PM
How did you "clean" carb?
jhow66 is offline
post #5 of 7 (permalink) Old May 20th, 02, 06:38 PM Thread Starter
i cleaned the carb with some carb cleaner the kind in a spray can.
post #6 of 7 (permalink) Old May 20th, 02, 08:25 PM
Vintage 68's Avatar
I know you have probably checked this but, are you sure it's not 180 off?
I would bring #1 to TDC (FIRING - not intake stroke) and reset dist to the #1 rotor to dist. terminal location.
If this is the original dist. for the truck and you feel around the back of the manifold and the base ring on the bottom of the dist. where it touches the manifold you will feel a little slot - that is the factory timing mark. You can set it so the marks line up and the timing will be the same as from the factory originally.
Vintage 68 is offline
post #7 of 7 (permalink) Old May 21st, 02, 05:58 PM
David Pozzi
davidpozzi's Avatar
Make sure the weights are not on backwards, if you had them off...
David's Motorsports page
First Gen Suspension Page
davidpozzi is offline
