ATTENTION ALL TRANSMISSION SPECIALISTS - Team Camaro Tech
post #1 of 2 (permalink) Old Nov 6th, 01, 03:20 PM Thread Starter
Hello! I have an 1982 Camaro and I changed the transmission from a 200 metric to a 350 trans, Now the problem is now my speedo does not work. When I turn the cruise control cable by hand under the hood it does work. Which narrows it down to the transmission tail shaft. Has anyone ran into this problem when switching transmissions? How do I correct it? Thanks!
barry barry
355 camaro is offline
post #2 of 2 (permalink) Old Nov 9th, 01, 02:28 PM
Stephen Dale
Guest
Posts: n/a
Don't forget to check your lower cable as well. Breakage is obvious but sometimes the square end won't seat or could be rounded off. Also check the driven gear, it"s only plastic and could have stripped or broken.
67 Nemesix
