Car Keeps Dying - Team Camaro Tech
post #1 of 16 (permalink) Old May 19th, 03, 08:29 AM Thread Starter
Unhappy
I have a problem, everytime my car is in park, or I put my foot on the break, when it's in drive or reverse(say at a stop light or stop sign) my car starts shaking, and then it dies. The battery light flashes on and off and my check engine light is on(my b/f's dad checked it out and couldn't find anything) so do you have any ideas? I have an '81 305 V8. I think it hates me, please help..tell me what I can do or check out and see what's wrong with it. Thanks. [img]graemlins/clonk.gif[/img]
CamaroChic4223 is offline
post #2 of 16 (permalink) Old May 19th, 03, 10:00 AM
Just wanted to say welcome to the site. My want to check you alternator and see if its charging like it should be. And check the battery also. Most the time when you have problems with the alternator the battery is not far behind. Hope this helps. [img]graemlins/beers.gif[/img]
CamaroJSU is offline
post #3 of 16 (permalink) Old May 19th, 03, 03:26 PM
Lightbulb
have you tried increasing the idle screw to make it idle faster? thats my only idea.
shane_c2003 is offline
post #4 of 16 (permalink) Old May 19th, 03, 04:32 PM Thread Starter
I did indeed tweek the idle screw and it helped for a while then it started doing it again. It's really annoying.
post #5 of 16 (permalink) Old May 19th, 03, 11:46 PM
When was the last tune up?
Snatchin'gears is offline
post #6 of 16 (permalink) Old May 20th, 03, 05:38 AM
Gary
MangeMD's Avatar
Does it shudder when you accelerate? Have you checked the coil?
1967 RS Coupe (clone): 406 SBC, Thorley headers, Muncie, Hotchkis suspension, Centerline Matrix 17" wheels with Nitto 555's, Baer brakes, 12 bolt 3.73 posi, RS conversion, Vintage Air, PPG Hot Red. (SOLD)
1968 RS Coupe: Project...Mini-tubbed, Cammed LS 6.0, T56, 12 bolt 3.73 posi, Ridetech 4 link...slowly adding more...
MangeMD is offline
post #7 of 16 (permalink) Old May 20th, 03, 07:21 AM Thread Starter
Red face
Ya'll are going to think I'm really stupid...but I don't know how to check any of this stuff..and I can't afford a machanic. *embarrassed* I just need ideas of what could be wrong, so I can tell someone. [img]graemlins/clonk.gif[/img]
post #8 of 16 (permalink) Old May 20th, 03, 01:25 PM
ZZ_430's Avatar
It might need to have the mixture control solenoid adjusted or replaced.
The carb is computer controlled, and had several adjustments.
My first checks would be the Mixture Control solenoid "dwell", and idle mixture screws. Some test equipment and special tools are used.
Those carbs can be a pain, and are expensive to replace. If emissions laws or originality are not concerns, you could consider going with an older style carb and distributor, and "deep-six" the computer. 81 was really the first attempts the factory made with computer controls, and they leave a lot to be desired.
Don ~ TC Member #15 ~
Don't mess with Texas!
ZZ_430 is offline
post #9 of 16 (permalink) Old May 20th, 03, 02:31 PM
Power booster vacumm leak, Clue, starts to die out when you put your foot on the brake.
Rob.Canada is offline
post #10 of 16 (permalink) Old May 21st, 03, 02:43 AM
I agree with the brake power booster.I had a problem with a mustang that would die when I stepped on the brake.
Standard 69 under construction.
KC69camaro is offline
post #11 of 16 (permalink) Old May 21st, 03, 09:59 AM Thread Starter
Any hints on how to fix it? after all I am broke and don't know a whole lot...
post #12 of 16 (permalink) Old May 21st, 03, 10:39 AM
robert
rolling-robert's Avatar
had same problem with my camaro (3rd gen like yours)
the check engine light comes on because the engine isnt running anymore while your key is in the ON position, so that works like it should.
OR the idle mixture screws are not set good OR the vacuum on your vacuum-advance is not working like it should.
maybe it can also be a worn fuel pump and turning the idle higher will solve it (because the fule pump needs some revving to pump up the gas)
Ill bet my cars its 1 of these problems.
Give your b/f a repair manual of your car for his birthday
Z28 1984
'77 355ci/COMP cam 218/224 .464/.470 114 LSA
rollerrockers1.5/9.72 forged pistons
ported '66 461 heads 1.94,1.5/Flowtech shorty headers
edelbrock 600/performer rpm intake
th350/shiftkit/hughes2500stall
4th gen 3.23 10 bolt POSI.
rolling-robert is offline
post #13 of 16 (permalink) Old May 21st, 03, 01:16 PM Thread Starter
Lightbulb
Eh...I've pretty much given up on getting other people to fix my problems...i've noticed that the only way anything gets done, is if you do it yourself...that's why I'm asking what it could be so I can fix it...I have the manul and have been reading it...Just the idea of trying to fix it then screwing it up even more..worries me. I'll try what you guys suggested, thank you [img]smile.gif[/img] I'm moving in 13 days and need to get in it good shape so maybe it'll sell...people tell me 1500 is too low..whatcha think? Thanks. [img]graemlins/clonk.gif[/img]
post #14 of 16 (permalink) Old May 22nd, 03, 05:23 AM
Cool
Timing chain may have slipped a tooth if engine has alot of miles on it. Check local newspaper for pricing of others in the same area and price yours a hundred or so less and stick to your guns on the price if you have to sell. Hopefully, you don't have to travel far..........
post #15 of 16 (permalink) Old May 22nd, 03, 05:24 AM
Cool
