need help badly - Team Camaro Tech
post #1 of 2 (permalink) Old Oct 13th, 02, 07:51 PM Thread Starter
I have a 93 Z28. The problem is that I never know when it will start. I can turn the key and it may start right up or it may just make a single click. This may go on for a few minutes, but it will eventually start. It seems completely random. I've had my brother's mechanics work on it and they had two electric shops look at it. The starter was replaced and all diagnostics indicated that the car should have been starting. But still just a single click. Or sometimes it starts right up. Any ideas?
psynce75 is offline
post #2 of 2 (permalink) Old Oct 14th, 02, 03:02 AM
Does the car have VATS? The resistor in the key?
Next time it doesn't start, wait for a min 3-4 minutes, then try to start with the same key.
If it does start, and the same effect happens for later start-ups, I would probably change the ign lock cylinder due to the key socket being spread apart.
Inside the socket, there are two leaves rubbing on the key resistor. Every time the key is inserted, the leaves spread apart.
I had this happened to a friend's '91 Cadillac. Worked great after fixing.
If it still clicks, after hot starting or cold starting, I would clean the battery cable ends, both ends of the cable(s). Should have less than 0.3 volt drop from the battery post to the solenoid terminal when measured with a voltmeter.
Everett "OBJECTS IN THE MIRROR DISAPPEAR UPON RAPID ACCELERATION"
