going dead? - Team Camaro Tech
post #1 of 2 (permalink) Old Jan 2nd, 00, 04:21 PM Thread Starter
i have new alt. new battery car stays charged 1/2 day, can anyone help?
Tommyguns is offline
post #2 of 2 (permalink) Old Jan 2nd, 00, 04:39 PM
Sound like you have a voltage draw, disconnect a terminal from the battery, (Pos or Neg), Hook up a test light between the terminal and the battery, If the light is on you have a draw some where, Start turning off the accesories and goodies, pull the dome light fuse first, Is the light still on?
Yes - Keep pulling fuses untill the light goes out.
No - Then you have found the circuit that is draining your battery, start checking components of that circuit for a problem
Rob.Canada is offline
