stalls when in gear - Team Camaro Tech
post #1 of 7 (permalink) Old Jan 23rd, 02, 12:53 PM Thread Starter
scott67ss396's Avatar
72 camaro,
timing was off fixed it, but when it is in gear it sputters then dies
and it sounds like %[email protected]%#.you can keep it going by giving it gas but if you let off it will die check the pluges too. just started doing this.
350
HEI
cam is a 234 at .50 with a 488 lift
12 bolt with 3.73 gears
400 trans
scott67ss396 is offline
post #2 of 7 (permalink) Old Jan 23rd, 02, 01:30 PM
Jody
camcojb's Avatar
What convertor are you running? That cam needs a higher stall than stock to idle in gear. There's a couple of things you can do to help it but you really need a looser convertor (if you don't already have one).
Jody
camcojb is offline
post #3 of 7 (permalink) Old Jan 23rd, 02, 01:35 PM
whaen you say the timing was "off" and you "fixed" it, what do you mean? it could be that the timing isn't "right" yet. how did it run before you fixed it?
355sb, vortec heads, HOT cam,T-10 tranny, 3.70 gears 16X8" IROC wheels
see pics here http://community.webshots.com/user/novaderrik
novaderrik is offline
post #4 of 7 (permalink) Old Jan 23rd, 02, 02:04 PM Thread Starter
the cam has been in for the last 4 months ran great. friend took it out ran it hard
the distributer was lose and moved the timeing back. i will take it back out again and set it tdc again
a new converter is my list the old 1 is stock
any thing els i may look at?
thanks again
post #5 of 7 (permalink) Old Jan 23rd, 02, 02:57 PM Thread Starter
and to just add to the fire
is that the trans leaks out the rear shaft i have replaced this thin like 3 times. trans fluid is all over the bottom of the car could the yok be bad it has some pits in it? and we just checked the trans fluid and its almost gon. would that make the engine stall while in gear?
just a thot
post #6 of 7 (permalink) Old Jan 25th, 02, 07:11 AM
Matt Jones
The fluid is probably leaking out of the back because you are running a short driveshaft for the TH400. The TH350 (and I believe all the others?) are all shorter than the TH400 shaft.
1969 Base Camaro
Vortec 350, TH-400
All sheetmetal is NOS GM
Silver69Camaro is offline
post #7 of 7 (permalink) Old Jan 25th, 02, 03:12 PM Thread Starter
Cool
well, we think that we fixed it the timing was way off,and we replaced the fuel filter too seems to be ok now we must get to work on the trans.
thanks guys for the help
