84 CHEVY CAMERO Z28 REBUILD - Team Camaro Tech
post #1 of 2 (permalink) Old Aug 27th, 99, 04:21 AM Thread Starter
305 H ENGINE CODE, MANUAL TRANSMITION
I REBUILT MY ENGINE AND I AM HAVING TROUBLE STARTING IT. I DONT KNOW IF I HOOKED THE STARTER WIRES UP RIGHT. I HAVE TWO BIG WIRES, ONE RUNNING FROM THE BATTERY AND THE OTHER ONE FROM THE WIREING HARNESS. THERE IS ALSO A SMALL WIRE.
THE SMALL WIRE IS CURENTLY HOOKED TO THE SMALL BOLT MARKED WITH AN S. I DONT KNOW IF THIS WIRE SHOULD BE HOOKED TO THE S OR THE R BOLT ON THE SELONOID. WHEN IT IS ATTACHED TO THE R THE STARTER DOSNT CRANK. WHEN IT IS ATTACHED TO THE S SIDE OF THE SELONOID IT CRANKS THE ENGINE BUT WHEN I TURN THE KEY OFF IT DOSN'T STOP CRANKING. WHICH BOLT DOES THIS SMALL WIRE CONECT TO THE R OR THE S, AND AM I MISSING ANY WIRES? DO YOU HAVE ANY IDEAS AS TO WHAT MY PROBLEM MAY BE? PS. I HAVE AN MSD IGNITION HOOKED UP, COULD THIS ALSO BE A FACTOR?
TIMMYSHWAGG is offline
post #2 of 2 (permalink) Old Aug 27th, 99, 11:10 AM
I'm thinking a purple wire to the inside terminal, next to block. Starter staying in could need a shim or two so it can back out of the flywheel. Shims go between the starter and the block. Might try loosening the starter bolts a little (not a good practice, I'll admit) and trying it once. If it works ok put a shim or two in there. tom
tom3 is offline
